New front bar installed, unfortunately I found out the blinkers don't fit AFTER putting it all back together.
I'll need to source some S2 blinkers to install and solder on.
This required a whole new S2 reo to be installed and headlight brackets, took me the whole afternoon.
Also put the front set of mudflaps on the car, I'll put the back ones on later.
  • Like 3
Yeah a little louder, not sure if it's quite whoosh whoosh gangsta though. The stock box actually isn't all that bad once you remove the blocking plate on the passenger guard side.
Edited by cpark
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
