My thoughts Exactly !!! Cannon is for the Kids and Mind Meltingly loud with the Bung out.
Couldn't pass this up at 99% new. 3" in and out into Twin 3" tip.
It's stainless but I'll just get a Mild Steel pipe welded on.
I know I'm gonna Love it. :D
Same brand as make of car - wow, coool
What you mean? Do Speco make the stock gauges / cluster?
I like them cooz they look very close to stocker style. (like we were talking about recently.)
ARCE!
It's one of these. ---->> http://www.magnaflow.com/02product/shopexd.asp?zone=main&id=11290
Gauges will look tidy as I think. No bells or whistles. Just Gauges. Undecided whether to light them up Blue or Red.
Edit* We'll see if $150 worth of gauges works for longer than $45 worth. LOL
  • Like 1
Ebay! ---->> http://stores.ebay.com.au/999autoshop/GAUGES-/_i.html?_fsub=3538745016&_sid=1100003286&_trksid=p4634.c0.m322
This guy had all 3, others only had 2/3 matching. I think I got my Belts or Cam Cover Seals from them too. :unsure:
In yet ? Keen to C
In yet ? Keen to C
Maybe later Big Fella. Too Knackered lastnite.
Rob,
i have a 3" stainless flange if you want it.
Actually got 2 but youd only need one right?
Thanks Mik but I asked the guy (Roadway Exhaust) what the best way to go would be.
a) Cut the Cannon off and put a flange on it + the pipe + the muffler.
He reckoned too Many Flanges. I told him you can NEVER have too many Flanges. *giggles*
b) Weld a pipe and flange onto the Muffler.
This he is going to do.
Mild steel pipe is half the price of Stainless and will last ten years.
One of these things is Not like the other...
I didn't realise til I pulled the Boost Gauge out (last) that they don't match.
I specificaly went for the ones with the black dealy on the needle.
Oh well, I'll put them in anyway and maybe buy another one. If anyone is keen for an all Red Needled one, perhaps we can do a trade or something.
Yeah steel is the smart choice.
but i mean the muffler, isnt that stainless, do you need a flange for it, or has it already got one?
just they are $40 each and ill never use these, so rather than pay for one, get mine for nothing.
If you need it.
The Stainless muffler will be welded to a Steel Pipe which will need to bolt up at the diff, so I guess the Flange will likely just be a Mild Steel one. I probably don't really need it as the whole welding/ bolting is only $120 to do.
But if I get him to do the multi-flange choice a) then I would need 3 flanges to be able to swap from muffler to cannon at will.
Maybe can I get both from you for $$$ just in case? or grab them and if I don't use them, I'll give them back to you. :D
Sweet! :thumbsup:
Gauges are in (Not all sensors hooked up yet) but the boost gauge works well. Snappier response than my old Type-R Ebay jobby.
Will have to do some trickery to get some Red or Blue leds in them but for now we have Default Bulb Glow.
  • Like 1
looks good rob, you got me thinking - i reckon thats the gauge I will go with in my spare DIN slot - did you get the electronic gauges?
Also; http://www.ebay.com.au/itm/SPECO-50MM-METER-STREET-SERIES-2-0-30-PSI-MECHANICAL-BOOST-VAC-GAUGE-/331041375905?pt=AU_Car_Parts_Accessories&hash=item4d139a86a1 looks like the boost gauge equivalent
Mechanical boost and electric water and oil temp.
That's the gauge I wanted and the guy I got from.
I have sent him a message about the mismatch. :(
I like them. :D
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
