So , can the Vipec read a brand new CAS as well as the OE computer ? I'm beginning to wonder why Nissan stayed with this optical cam driven CAS as long as thy have and not just reverted to a simple crank trigger . Why high reving RB26s didn't get them std is strange .
A .
  • Replies 65
Surely the standard late 80s and 90s Nissan control boxes were not computing power houses . I keep reading that the CAS outputs a high frequency signal and thats what aftermarket computers have problems with . I also keep reading that belt/chain driven cam angle sensors have all sorts of ignition scatter problems and that makes it difficult to tune with good accuracy .
Just for the record did the GMS GTRs run Electromotive computers and did they have crank triggers by any chance ?
If so they though a lot of the factory cam driven CAS ...
If there was a simple affordable way to attach a crank trigger wheel to the standard crank pulley that would be the way to go . You still need a cam reference so the brain can tell which of the two revolutions a four stroke sequentially injected engine is on but thats real simple anyway . A Cas disc with a single hole could do that . Or another Hall sensor and rotor .
The big dollar builds should be all over this , cheers A .
Well, its not a problem all big dollar builds encounter either buddy. The distortion you speak of has a bit to do with belt noise and interference, this has been attributed to certain makes of belts i believe. In reality, you are overthinking this waaaay too much. Its a good ecu, ALL of todays breed of ECU's are good, cept microguess. Honestly, talk to your tuner, nut it out with him and go from there. If you have a signal interference issue, sort it then. If you want an absolute hassle free system thats going to be there forever, open your wallet to the tune of 45+k and call Motec, get a setup with all the fruit, and be happy with a 60k build for 250rwkw.
Yeah thats what I think yet the web and market is full of aftermarket CAS discs with a lot less slots in them .
I did speak to Scott at Insight and he said get a nrw CAS if its more than a few years old . By CAS I'm not sure if he means the whole CAS assembly or just the internal electrical ring with the photo diodes in it . Then if this Vipec plug in can get good accuraye signals from it no problem .
I just don't get why Nissan went with an ancient early 80s optic system when Hall triggers are so simple and cheap . Toothed wheel bolted to the back of the crank pulley and a hall sensor , another for the exhaust cam that requires little accuracyand Bobs yer uncle . Nissan actually had this system for one year (1981) in 280ZX Turbos with L28ETs only they had the cam reference hall sensor in the distributor , aside from a rotor button and cap thats all the dizzy had .
Anyway waiting for Insight to open in the new year .
