r32 gtr long motor with rebuilt stock bottom end, also has N1 oil pump and water pump.
This engine was in a 300zx (drag car) I had for a few months that made 520rwkw. The head was sold so I put a spare stock 26 head I had lying around on it.
The head was decked/pressure tested and a new head gasket and new ARP head studs were installed. Compression was perfect as it was reabuilt recently prior to the head swap.
Pick up Valley Heights Sydney or can ship.
$2,500
Pete
long motor includes what??
bottom end and head but no rocker/cam covers, no intake and exhaust
has a sump but it's a zed one, just swap a stock one on
comps test?
compression test was done when i got the car and it was 145 all round, stock head has just been placed on it but not torqued down yet so no comp test done after that. Stock head is in good nick.
  • 3 weeks later...
Isn't this the motor u spun a bearing on ??
you may be thinking of someone else, i have had about twenty rb26dett powered cars and i have never spun a bearing(touch wood).
however other engines(in my race car) have popped headgaskets, blown/cracked pistons or slowly lost compression.
this long motor was removed in good condition(to sell the head off).
head is not torqued down so any buyer can pop it off and have a good look around whilst i drink a beer and talk shit
pete
ps i appreciate your inaccurate contribution to this thread
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
