r32 gtr long motor with rebuilt stock bottom end, also has N1 oil pump and water pump.
This engine was in a 300zx (drag car) I had for a few months that made 520rwkw. The head was sold so I put a spare stock 26 head I had lying around on it.
The head was decked/pressure tested and a new head gasket and new ARP head studs were installed. Compression was perfect as it was reabuilt recently prior to the head swap.
Pick up Valley Heights Sydney or can ship.
$2,500
Pete
long motor includes what??
bottom end and head but no rocker/cam covers, no intake and exhaust
has a sump but it's a zed one, just swap a stock one on
comps test?
compression test was done when i got the car and it was 145 all round, stock head has just been placed on it but not torqued down yet so no comp test done after that. Stock head is in good nick.
  • 3 weeks later...
Isn't this the motor u spun a bearing on ??
you may be thinking of someone else, i have had about twenty rb26dett powered cars and i have never spun a bearing(touch wood).
however other engines(in my race car) have popped headgaskets, blown/cracked pistons or slowly lost compression.
this long motor was removed in good condition(to sell the head off).
head is not torqued down so any buyer can pop it off and have a good look around whilst i drink a beer and talk shit
pete
ps i appreciate your inaccurate contribution to this thread
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
    • Just to get this straight if you turn the splined shaft to the outside, it turns freely but the chain does not move? What happens when you move the chain, does the splined shaft turn? Surely the shaft is snapped, or the chain is seized and it took the teeth off whatever great is behind the steel bracket
