I am parting out a complete r32 coupe rolling shell some stuff is gone already such as the stereo surround and dash vents, castor rods, sideskirts and rear pods.
all panels are straight but will require re painting
almost all other parts available such as:
front bar and reo bar - $150 each
mint projector headlights - $230
mint indicators ( genuine clear type) - $140
doors - $100 (shell only)
guards - $80 each
mirrors - $50 pair
door cards -$50 each
interior C pillar trims vgc - $150 pair
bonnet - $120
bonnet latch - $60
stock suspension components - from $20
rear diff - $ 150
seats - $50 each
seatbelts $ 50 each
carpet $100
roof lining - $100 (sunroof)
wiring looms - from $40
fuel tank / pump - will post price once Ive checked out the pump
full 3" stainless exhaust (cat back) - $200
all glass - from $50
rb20 engine crossmember - $150
most engine parts like manifolds and p/s pumps etc - from $20
coilpacks - $130 for mint set (stock ones)
ecu's (rb20det and rb25det) - $130 each
I also have some running gear like a rb20det engine that needs rebuilding - $200 and a excellent rb20det gearbox - $550
please note I will be selling all the hubs and brakes as a full 5 stud conversion kit (I do have a spare pair of r32 front hubs and knuckles) which will not be for sale for about a month as I still need to be able to move the car around at this stage
please contact me for prices or photos some parts I will be negotiable on prices some I will not :) and im located in algester 4115
also got stuff like:
manual rwd speedo cable - $80
r32 clutch pedal, master and slave cylinders with lines - $150
r32 cluster $70
r32 cluster surround with working switches - $120
good r32 rear C pillar trims - $150 for the pair
rb25det igniter - $80
rb25det into r32 wiring harness - $250
lots more to come :)
good r32 dash with no holes or cracks (does have a bubble above glove box area) still has small round vents and demister vents - $80
good centre a/c vent - $60
full boot interior (carpet and plastics) - $60
r32 clutch pedal, master and slave cylinders with lines - $150 - sold pending payment
r32 gtr intercooler - $150
r32 stock lca's - $60
r32 coupe tail lights - $80
rb20det (cefiro) igniter module - $80
passenger window switch at any chance? pm me
nah sorry mate you already asked me on my other topic :)
4dr_32 I think i've got one here with very good plugs will be $100 if I do (they're very hard to find with good plugs)
Cheers
awwwww yehh, post to 5158?
your coilpack loom was posted yesterday :) cheers
also sold the front reo bar, tail lights, half shafts, manual pedals and tailshaft, and the stock rear bumper
how much for the passenger side switch with the wiring
you have a pm :)
goingforadds you also have a pm...
and no parcel shelf cover sorry ADUBZ
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
