Hey guys,
I am a bit of a newbie to SAU forums, I used to be on hardtuned.net alot but the 17 year olds with bad attitudes got a bit much.
I have a track car thats not complied for australian roads, I keep reading just about every week about a skyline, stagea, etc getting stolen and its making me paranoid. I live in Adelaide and the car is usually stored at home, I have a cheap wheel clamp on one of the front wheels but its pretty basic.
Being a track car I really dont want to fit an alarm as such, I really dont need the headache if the thing plays up as it would be really a pain to get the car back to wherever it gets fitted for warranty work.
I cant imagine I am the only guy out there with the same situation, what are people using to protect their pride and joy ?
I know there are other topics about this, but it seems the flaming of people takes precedence over helpful information.
So please refrain from turning this into the same, I really dont need the bother.
Edited by Ricky_Bobby
https://www.sau.com.au/forums/topic/415918-how-do-you-protect-your-track-car/
A basic tracker can cost up to $800 depending on its features and the features you want wired up, the installation (whether you pay a pro or do it yourself) and of course the brand of product. A basic tracker will also need a simcard to send you location info whenever you ask it, and the costs associated with txt messaging which is very minimal if you use the same phone carrier as your personal phone. It would not cost more than $10 per month if you had it on a basic plan (Telstra). Some carriers offer a 365 day prepaid plan which needs topping up annually, with that kind of plan it would probably cost around $20 for the whole year. There are no other annual monitoring costs or subscription costs associated with these trackers because you are doing the monitoring personally. They are a one time purchase product so you can remove it and put it into your next pride and joy.
You can be lying on a beach on Hamilton Island and know exactly where your car is within seconds.
You can get mini GPS trackers on Ebay for $50.
Just get a prepaid sim card with 365 days expiry for $30
That's it.
They are rechargeable or you can wire them to your battery.
Comes with PC software for tracking.
So you can pole (call) it anytime and the location is sent to your phone or PC.
I think each time is the same charge as an sms.
Gotta be the cheapest way for tracking.
If you're mainly worried about drive off theft, and only drive a couple times a year, disconnect your battery and pull some key fuses out.
That's it.
A mini tracker is fine for tracking a girlfriend lol or your skate board
But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips
and be able to be hidden in a stripped car as well
yes it can be done
expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car
The catalog points out the flaws that failure to communicate starts around 30c
( iPhones do that too )
It has no external antennas so range is average if it can't see the sky clearly
Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc
Telstra towers are the best option in most cases and services that use those
so as you can see going cheap might cost you a car !!
A mini tracker is fine for tracking a girlfriend lol or your skate board But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips and be able to be hidden in a stripped car as well yes it can be done expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car The catalog points out the flaws that failure to communicate starts around 30c ( iPhones do that too ) It has no external antennas so range is average if it can't see the sky clearly Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc Telstra towers are the best option in most cases and services that use those so as you can see going cheap might cost you a car !!
Thats a fair point, I wonder if there are ruggedized (yes its a word !) versions or maybe I can make my own.
Being in South Australia, you could almost say 80% of the year the inside of the car will be 30degrees or hotter. So that probably rules the cheaper option out , surely somebody (a manufacturer) has identified a spot in the market to make something that can withstand these sorts of issues but without the $800 price tag. Seems excessive for a pretty common technology these days ?
Plenty in the 200-250 range without install
external antennas ( tiny ones)
And alloy case with heat sink ( tiny too)
at least 10 companies make them not including eblow ones
They offer full features and can trigger a remote item like alarm or kill switch
They send out GPS coordinates in SMS and clicked onto it google earth or maps opens
Highly accurate tested to within 1 meter of real location in a poor coverage area with lots of metal and houses around it
a rubber mat and soft rubber mounting used on screws fixes up a fair bit of vibration
It also stops heat transfer from the actual car body a bit without breaking the ground plane
Most of the heat is from car, motor or sun , the unit is only room temp otherwise even charging up
I never referred to a mini tracker in my earlier post and if they cost $50 then why shouldn't they play up and fail in 6 months. You cannot expect quality for that price even for a kids toy these days. If you cannot afford a $300 to $400 vehicle tracker and you have a track car that you have spent thousands of dollars on then just strap your car down with $50 worth of chains and padlocks people!
People spend thousands of bucks on car audio, engine and interior, but do not want to spend a few hundred dollars for its security???
The better products that I am referring to will not fail, due to heat and vibration and I have never seen one fail as a result of this. Been fitting them for years to everything including track cars and excavators. They also have separate antennas for both GSM (to communicate to the owner) and GPS to collect data from the satellites.
I do not have any links where you can purchase these trackers but Google will give you plenty of results. I am here to advise on security options, not to do the shopping around for people.
The $800 price tag I mentioned was a general price (as I cannot give accurate prices for everyone that sells them) and would be the highest price you would probably pay which would include installation. This is still quite cheap compared to a monitored tracking system and service which can cost up to $2000 for the tracker and installation plus $200 - $300 per year for monitoring costs. If you want accurate prices then do some searching, make some phone calls, compare their prices and their features.
If your budget is only $50 then your cheapest option is to sleep in your car or sell it to pay the bills.
Yeah what Daniel said lol
+1
contact quiktrack i had one of their systems in my s15... much better then any of the ebay ones but theres montly fees ect, but other advantages as where car can be turned off via satellite systems.
http://www.quiktrak.com.au/
My advice, don't contact Quiktrak, as they are way too expensive! Arn't we talking about keeping the costs down?
Most basic trackers that I refer to can still shut the car down by you, by a simple sms text message whenever you want to. Also can unlock doors by sms if you lock you keys in the car by accident.
Exactly what I was going to say mate lol
Any decent tracker can do remote shut downs and much more and cheaper then quicktrak or DEI viper setups
But these "how to's" won't be advised to the DYI ever , if you don't follow that warning you could kill someone !!
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
