Hey guys,
I am a bit of a newbie to SAU forums, I used to be on hardtuned.net alot but the 17 year olds with bad attitudes got a bit much.
I have a track car thats not complied for australian roads, I keep reading just about every week about a skyline, stagea, etc getting stolen and its making me paranoid. I live in Adelaide and the car is usually stored at home, I have a cheap wheel clamp on one of the front wheels but its pretty basic.
Being a track car I really dont want to fit an alarm as such, I really dont need the headache if the thing plays up as it would be really a pain to get the car back to wherever it gets fitted for warranty work.
I cant imagine I am the only guy out there with the same situation, what are people using to protect their pride and joy ?
I know there are other topics about this, but it seems the flaming of people takes precedence over helpful information.
So please refrain from turning this into the same, I really dont need the bother.
Edited by Ricky_Bobby
https://www.sau.com.au/forums/topic/415918-how-do-you-protect-your-track-car/
A basic tracker can cost up to $800 depending on its features and the features you want wired up, the installation (whether you pay a pro or do it yourself) and of course the brand of product. A basic tracker will also need a simcard to send you location info whenever you ask it, and the costs associated with txt messaging which is very minimal if you use the same phone carrier as your personal phone. It would not cost more than $10 per month if you had it on a basic plan (Telstra). Some carriers offer a 365 day prepaid plan which needs topping up annually, with that kind of plan it would probably cost around $20 for the whole year. There are no other annual monitoring costs or subscription costs associated with these trackers because you are doing the monitoring personally. They are a one time purchase product so you can remove it and put it into your next pride and joy.
You can be lying on a beach on Hamilton Island and know exactly where your car is within seconds.
You can get mini GPS trackers on Ebay for $50.
Just get a prepaid sim card with 365 days expiry for $30
That's it.
They are rechargeable or you can wire them to your battery.
Comes with PC software for tracking.
So you can pole (call) it anytime and the location is sent to your phone or PC.
I think each time is the same charge as an sms.
Gotta be the cheapest way for tracking.
If you're mainly worried about drive off theft, and only drive a couple times a year, disconnect your battery and pull some key fuses out.
That's it.
A mini tracker is fine for tracking a girlfriend lol or your skate board
But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips
and be able to be hidden in a stripped car as well
yes it can be done
expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car
The catalog points out the flaws that failure to communicate starts around 30c
( iPhones do that too )
It has no external antennas so range is average if it can't see the sky clearly
Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc
Telstra towers are the best option in most cases and services that use those
so as you can see going cheap might cost you a car !!
A mini tracker is fine for tracking a girlfriend lol or your skate board But the specs don't hold up well to Australia's climate , the solder joints need to be able to survive track bashing suspensions and rpm vibrations , ripple strips and be able to be hidden in a stripped car as well yes it can be done expect the mini tracker to last about 6 months if that !! even jaycars do not meet the heat here and that is in a closed air condition car not a hot race car The catalog points out the flaws that failure to communicate starts around 30c ( iPhones do that too ) It has no external antennas so range is average if it can't see the sky clearly Another point is use a cell service that has many towers in your band , 900mhz , 2100mhz etc Telstra towers are the best option in most cases and services that use those so as you can see going cheap might cost you a car !!
Thats a fair point, I wonder if there are ruggedized (yes its a word !) versions or maybe I can make my own.
Being in South Australia, you could almost say 80% of the year the inside of the car will be 30degrees or hotter. So that probably rules the cheaper option out , surely somebody (a manufacturer) has identified a spot in the market to make something that can withstand these sorts of issues but without the $800 price tag. Seems excessive for a pretty common technology these days ?
Plenty in the 200-250 range without install
external antennas ( tiny ones)
And alloy case with heat sink ( tiny too)
at least 10 companies make them not including eblow ones
They offer full features and can trigger a remote item like alarm or kill switch
They send out GPS coordinates in SMS and clicked onto it google earth or maps opens
Highly accurate tested to within 1 meter of real location in a poor coverage area with lots of metal and houses around it
a rubber mat and soft rubber mounting used on screws fixes up a fair bit of vibration
It also stops heat transfer from the actual car body a bit without breaking the ground plane
Most of the heat is from car, motor or sun , the unit is only room temp otherwise even charging up
I never referred to a mini tracker in my earlier post and if they cost $50 then why shouldn't they play up and fail in 6 months. You cannot expect quality for that price even for a kids toy these days. If you cannot afford a $300 to $400 vehicle tracker and you have a track car that you have spent thousands of dollars on then just strap your car down with $50 worth of chains and padlocks people!
People spend thousands of bucks on car audio, engine and interior, but do not want to spend a few hundred dollars for its security???
The better products that I am referring to will not fail, due to heat and vibration and I have never seen one fail as a result of this. Been fitting them for years to everything including track cars and excavators. They also have separate antennas for both GSM (to communicate to the owner) and GPS to collect data from the satellites.
I do not have any links where you can purchase these trackers but Google will give you plenty of results. I am here to advise on security options, not to do the shopping around for people.
The $800 price tag I mentioned was a general price (as I cannot give accurate prices for everyone that sells them) and would be the highest price you would probably pay which would include installation. This is still quite cheap compared to a monitored tracking system and service which can cost up to $2000 for the tracker and installation plus $200 - $300 per year for monitoring costs. If you want accurate prices then do some searching, make some phone calls, compare their prices and their features.
If your budget is only $50 then your cheapest option is to sleep in your car or sell it to pay the bills.
Yeah what Daniel said lol
+1
contact quiktrack i had one of their systems in my s15... much better then any of the ebay ones but theres montly fees ect, but other advantages as where car can be turned off via satellite systems.
http://www.quiktrak.com.au/
My advice, don't contact Quiktrak, as they are way too expensive! Arn't we talking about keeping the costs down?
Most basic trackers that I refer to can still shut the car down by you, by a simple sms text message whenever you want to. Also can unlock doors by sms if you lock you keys in the car by accident.
Exactly what I was going to say mate lol
Any decent tracker can do remote shut downs and much more and cheaper then quicktrak or DEI viper setups
But these "how to's" won't be advised to the DYI ever , if you don't follow that warning you could kill someone !!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
