Small update.......
A friend / club member of mine had diagnosed an issue with the clutch cooling fan..........the clutch fan was moving within the cooling fan not from side to side but forwards and backwards.............needless to say it had to get fixed.
So I took that step today.
After much debate and swearing in three different languages I managed to remove the cooling / clutch fan without removing the radiator cooling shroud (yes it's all possible)
I didn't go unsaved though
Anyways me being the clean freak that I am, I thought Id give the cooling fan a clean down
Nice and dirty
all clean :)
The next step was to install this little baby
Brand new clutch cooling fan
Thanks to Zac (Cowdy) for procuring this item for me so speedily
All fitted and ready to go back in its home ;)
That's it!
  • 4 weeks later...
If you want led's just get some eBay spec white led t10's they work a treat
You can get like 20 for $5
Can't wait to see what it looks like. But should that little much more brighter :)
Been busy paint stripping the rear bumper
post-5053-13943460057865_thumb.jpg anyone know how to remove the paint from the bottom bit? It's rough like the front bumper lip so very difficult to remove cleanly.
Also thought I'd tackled the shit spot welding on the back RHS rear quarter panel
All smoothed out with my trusty powerfile
Next will be a little sanding and then I will paint the rear panel in crystal white to make it nice and clean ;)
  • Like 1
Are you going to do anything with the spot welds you grinder back? Wouldn't be much straight left in the welds, if there's any weld left. I can't tell exactly where it is on the car. Thought about some stainless rivets, or rewelding it completely?
strength*
nah mate, the way theses spot welds have been applied is pretty full on and there is enough of it left on the car to keep everything nice and strong.
Should I feel the need for more bracing I would spot weld the entire car but it's not necessary...........for now
Spent all day at work reading this start to finish. Amazing. So awesome to see people like you restoring cars and spending so much money for nothing but the best! Love it! One day i'll own a '94 32 GTR V Spec II but for now, my Evo 8 MR will do :P
Keep up the good work!
Will get some LEDs for the reverse lights as well attachicon.gifImageUploadedBySAU Community1394346759.691514.jpg they are E4's by the looks of it
ive just done all the LED in my car Ants. PM me if you need the exact globe....
thank you very much mate. It's comments like this ^ that keep me going.
There are lots of good bits indeed.
But just a little correction it's not a V-spec it's just a late 94 model GTR :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
