Thought that Mike and I were coming down to your place tomorrow night and then drinking scotch and then going to Yattla for the cruise?
Ha! That would of been good.
Sadly I have already plans with family tomorrow
  • 1 month later...
  • 3 weeks later...
Well run in has been done (so I've been told)
As much as I want to go and get it tuned again I'm saving for suspension parts FTM as a car is only as good as it handles
I will put some minor updates soon ;)
  • Like 1
  • 1 month later...
Alright it has been quite some time since I have updated this build thread
I guess I have been enjoying it, hence why bugger all updates
but this aint true as I have in fact done a bucket load
First up........
I decided to take off the windshield water grill and see what has been lurking under there
so after taking off the mandatory wiper and bonnet bolts and removing them I got this
it wasn't pretty
so lets get all this cleaned up ;)
  • Like 1
Got my trusty garage vacuum cleaner and started sucking up all the dirt and silt lying within the under there grill
even took these little suckers out for some restoration lol
after a quick wipe with some warm water and soap and it already started to look a better
but me not being satisfied I wanted to go one step further
I removed the bolts to the wiper motors (except for the middle one so just tapped it up) and taped up everything else with plastic sheeting
next step was to apply a coat of clear where the windshield grill usually sits
results
  • Like 1
managed to clean them plugs rather well and went straight back in their home
whilst I was at it I thought I would pay some attention to the actual grill which looked rather in poor shape
After a quick wash with some sugar soap and warm water it looked like this
I glued the lip back with some Loctite Precision Super Glue Gel (highly recommend it for delicate applications)
Then I applied some Meguiars Plastx to get it to look like this
back in the engine bay - I had some broken studs to take off and rethread
after much swearing and broken drill bits I got the bastard out lol
me and drills - thank Christ I am not a dentist
Time for some rethreading
this is actually rather delicate to do and you must turn slowly then reverse slowly to get the right threading technique but I managed very well thanks to Youtube lol
new stud in place
next up the rear wing
thought I would take the rear wing off to detail it...........
lets just say that when I saw this
I knew that there was going to need more than just wax and polish
the rear wing stay brackets were fooked to say the least
totally corroded and unusable
the car without the rear wing
we will get all this cleaned up too
ta dah!
a bit of detailing done (cut and polish)
it sure does have a different appearance without the rear wing
  • Like 1
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
