for sale
(in parts section as it's not complete/ running
For sale is my old track car minus a few of the performance parts but comes with the STD bit to get running
Has
Wide body front guards
Flared rear guards
Adjustable aftermarket front lower arms , castor arms, rear lower arms , rear upper arms
And hicas lock bar
LSD diff shimmed to locked
Tien ha adjustable coilovers all round
Rb25det engine comes with hi flowed turbo all the rest is stock
Front mount cooler
Alloy radiator
Surge tank
5500 with remaining rego pretty much has everything to get driving
Ect I do have lenso's available 17x10 for 900 extra
Genuine greddy plenum for 650 extra
Splitfire coilpacks near new 500 extra
https://www.sau.com.au/forums/topic/416122-wide-r33-gtst-regoed-modified/
Rolling shell with STD Suspention 1800
Front lower control arms 250
Rear lower control arms 250
Camber toe hicas 150
Tien ha coilovers 500
Rb25 engine 800
R33 diff 300
Surge tank 100
Alloy radiator 150
Lenso's 800
Turbo, I was told was rebuilt by dr drift when I bought the car, seemed to run fine when I drove the car home , then I pulled it out
Will take 200 with brand new dump pipe
Coilovers, no knocks or leaks, there very firm as ha's are
Unknown kms but seem perfect all adjusters work
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
