Hey guys,
The engine in our 35 runs so smooth and feels like new so it was a surprise to me that one hot day on parra road the temp needle started to spike where it shouldnt to the point where i almost had to pull over. This was frustrating so yesterday i pulled up in the drive way and let it run on 3000rpm untill it started to get hot.. i jumped under the hood to find that only one of the 2 thermo fans were running. The passenger side fan was not working with the temp gauge at 3/4. Can anyone help me fix this problem? is there a fuse for it somewhere or anything i can trouble shoot to get it working again.
Cheers
https://www.sau.com.au/forums/topic/416354-radiator-fan-issue/
Didn't Alex discover that the PNM35 fans switched on very late (98 deg), and was able to lower the switch point to around 88-90 deg with his Uprev?
I wouldn't be surprised if this isn't a similar issue; along with improper bleeding.
Stock temp switch for the fans is 100 degrees. Uprev can set the temp to whatever ou choose.
Normally the fans won't switch on unless stuck in traffic, or idling for extended periods.
Look and the connections first, they are plugged in at the back of the fan. You can test by applying 12 volts to the fan, if no good then get a new set from wreckers.
But i agree, make sure no leaks, and correctly bled too.
the fan motors can burn out...
95 degrees? is that at the rad input or thermostat?
my car always runs at 2/3 to 3/4 on the gauge, replaced everything except for the gauge itself. installed my own thermo fan setup with a 78 degree switch between the rad output and thermostat... 78 degrees is at the 2/3 to 3/4 mark on the gauge, which was checked as being 78 degrees with a scantool aswell.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
