Hey guys,
I've bitten the bullet and decided to put my hard earn coin to use and make my R33 GTS-T go. I've collected around 6K to pour into my car which I think should be plenty of money to get everything sorted. My goal is to hit the 260-270 RWKW mark. I also don't want to advertise the fact that my car is worked so everything will be done as stealth as possible.
Current mods on car:
- BC racing coilovers
- Exedy HD cushion button clutch (<10000KM old)
- bellmouth dump pipe with catco high-flow and HKS silent Hi-power catback
- T-piece bleeder valve
- HKS mushroom pod filter
I've been doing a bit of research on this site, comparing other people's mods and going off by recommendations and advice and have come up with the following "2-buy" parts:
- Garrett GT3076R-12 low-mount kit with 0.70 A/R, internally gated
- Sard 550 CC injectors with collars
- Z32 AFM
- Bosch 040 fuel pump
- Nismo fuel pressure regulator
- Ebay Ching-Chong China cooler with piping kit
All parts listed come to a price total of around 4.5K, give or take couple of hundred dollars if i shop around. I've got a Z32 ECU with a NISTUNE board in it so on the tuning side of things, all is good. From the parts that I've listed, does everything sound A-OK? Any recommendations or any other additional parts I should be adding? I'd like to make sure I'm going in the right direction before I place a big order. Any money left over from the tune will be going straight on a 1.5 way diff and HICAS lock bar. I'll also be spraying the FMIC matte black for that stealth look.
Cheers,
For the turbo selection I'd say have a look over the Hypergear thread, cheaper turbo more "bolt on" some nice results shown and their SS series is made for an RB25, I'm no expert but I hear that the internal gate housings used on the gt30 are a bit rubbish.
Fuel pressure regulator also not really needed.
Cheers for your input. I'm keeping my options open at the moment and will be giving hypergear a call and see what they can offer me. Handy too because they're only around the corner from me.
+1 for checking out Hypergear. And for scrapping the fuel regulator, stock is fine. If anything maybe go for some bigger injectors in case you increase your power goal in the future. Also, ditch that HKS pod filter. The filter element in them is rubbish. Would run a $20 pod from Supercrap before I used a HKS filter.
With the turbo, the 3076's with Nissan 6-bolt housings have pretty average results from what I've seen, so if you do end up going for the Garrett then I'd advise comparing the results of the bolt-on kits vs the 4-bolt rear housings. Which would require a new dump pipe if you went down that route.
+1 for hypergear.
also say ditch the FPR and keep stock.
HG SS2, 3" metal intake, eBay cooler kit, injectors and a plug in map based ecu.
hypergear can bundle a turbo and ecu at a great price. Buy 850cc injectors at least. You will have an awesome car.
GL.
How bout a Cooling Pro intercooler kit from Just Jap, they would be bit better than the average Ching Chong cooler I think.
Much of a muchness, Cooling Pro is Chinese.
That said, I would still go through Just Jap or someone like that rather than eBay, customer support is usually better if you do run into problems.
Edited by Hanaldo
Looks like I'll be going through HyperGear for my turbo setup, only seems right :) like I said, I'll be giving the mob a call to help me choose the right turbo for my setup. With the cooling pro FMIC being a return flow on just-jap, will it still be sufficient for my setup as it uses the stock intercooler piping?
+1 for hypergear.
GL.
I already have a Z32 with NISTUNE so an ECU will no be needed :) When it comes to think of it, looks like I'll get 850 CC injectors just in case I want more power down the road.
+1 on ditching the FPR and getting larger injectors too. Once it's all installed you'll need a retune and that may be a good time to move to e85 as well if you can get easy access to it. More power so you can reach your target power goal easier and give your engine some safety from knocking.
+1 on a jjr cooler too, great guys to deal with and the stuff is at least decent quality. Also, have stealth cooler kits, and you can even get a return flow for extra stealth but you do lose a bit of airflow with the it compared to the traditional setup.
Could i suggest ditching the mbc and getting a good ebc as well ? Better boost control and you can get gain for more turbo response.
Oh, you might wanna budget some money for tires too, you'll need some s or r compounds to hold that power, unless of course you just want to fry tires and slide everywhere :D
Thanks for all your input guys, you've been of great help. From what I've gathered here from this thread it looks like ill be getting on to bigger injectors and ditching the nismo FPR. I'm not really fussed with what intercooler to go for as long as it provides good flow for now and the future when i chase for bigger power. I never really thought about an ebc, how are they more beneficial compared to the traditional bleeder valve? I've heard a lot of mixed opinions about ebc's, so I'm a bit skeptical. With the coilpacks, I bought a set of OEM brand new <5000 km ago, so if they don't hold up on bigger boost, a set of splitfires will come ;)
I wouldn't bother with an EBC on an internally gated turbo. When I had my old Hypergear, the ebc was essentially just there to increase my street cred and make noises, it didn't really do anything other than that. External gate is a very different story, but with an internal gate just get the actuator as close to the boost level that you want to run and run it.
You sound like you're about set, but also budget for a service before you get a tune. Always do oil/filter change when installing a turbo, fuel filter when installing new injectors, and spark plugs wouldn't be a bad idea either (making sure they are the correct gap etc). As well as anything else that looks like it might need replacing, belts etc. Speaking of injectors, I personally always get injectors flow tested before installation whether brand new or second hand. A mate of mine didn't think it necessary and ended up hydrolocking his motor from one of the Nismo 550's spraying like a fire hydrant. Up to you, but it's cheap piece of mind.
A good EBC will easily outperform 95% of mbc's out there. Only a few mbc's have as good turbo response as an ebc.
Depending on your tuning approach, you can get basic ebc that just have several boost profiles and gain setting (holds the wastegate shut) for best possible turbo response, all the way up to fancy ones that have settings overkill and can do funky stuff like gear/speed/rpm/throttle based boost for traction etc along with logging of data and intake air temp adjustment.
Just make sure you get a good ebc and you prolly won't look back :) (there's plenty of threads on sau detailing good ones).
For a jjr stealth cooler kit, check this out http://justjap.com/store/product.php?productid=19944&cat=339&page=1 (just spray the clamps black as well after installing).
Supposedly the oem coilpacks are just as good as splitfires when they are brand new ?? So you should be good there then.
Oh forgot to say as well, if you don't have any current brake upgrades, you'll definitely want to set aside some money for that as well.
Hope this helps dude.
OP, Hanaldo saying adjusting the wastegate actuator as close as possible also works :), you are generally limited to running one boost settings like this though, but less hassles, less failure points and electronics and less exposed flashy items in cabin and engine bay.
Here's a great thread on ebc's btw, if you wanted to read a bit more
http://www.skylinesaustralia.com/forums/topic/229928-dyno-graphs-comparing-pfc-boost-controll-vs-blitz-idiii/page__hl__apexi%20pfc%20boost%20controller%20vs
Awesome, all this info is what I need. I'll have a look into some ebc's. I like the thought of having a LO and HI boost setting. What kind of brakes are recommended without breaking the bank? All these things are starting to add up quite quickly. Will a exedy HDCB clutch hold 260-270 RWKW without disintegrating?
Cheers,
Contact gslrallysport on here and ask him about his Remsa pads. DBA 4000 series rotors or RDA rotors are both very good. The clutch you will have to see, some people love em lots of people hate em.
It does add up quick unfortunately, especially if you build it right the first time.. but generally doing it right the first time ends up being cheapest in the long run anyways.
It seriously comes down to what your intended purpose for the car is, e.g. if you just want the power for dragstrip action, don't worry about the brakes, tires, ebc etc but if you want it for circuit then brakes and tires are almost a must with that power level along.
Anyways for brakes, what Hanaldo said again.. generally rda is a bit cheaper than dba so 4 slotted rdas to suit gtst along with some good pads would be a great bang for buck upgrade. Your tires may need attentioning too =/
The HDCB clutch will hold that power level fine :)
I want my car to be great all-round with handling, speed and braking. I don't want to take any shortcuts. If my car's getting power, it also needs stopping power, so the RDA rotors front and rear with some remsa pads seem to be fine. I already have BC coilovers so the handling is already there. Might consider front strut brace as well but we'll see how far my funds send me. I'm also going to attempt to install all this gear in my car by myself with the aid of a close friend who loves doing this kind of stuff. I reckon it'll be a great learning curve for me and also an rewarding experience which will make me enjoy my car even more after everything's in place.
Just one more question, Once all the gear is intact, will I be able to drive to the tuner shop with the stock ECU in place?
Possible, but not real likely. Big injectors, + different AFM = possible large change in required injection time (per squirt). If the car will start and run relatively cleanly, and as long as the drive is not too long, then yes. If it is hard to start or unhappy to run with a few revs and a little load, then no.
My suggestion? Towing is less expensive than breaking shit you didn't need to break. And it doesn't take long to swap in injectors and an AFM, so you can always leave that sort of stuff to be fitted at the tuner's.
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
