That's right, that's happening!
I'm doing a much of the work as I can too.
I got the RB30 block from my old VL commodore after I cooked the head in good old VL commodore fashion. :)
I've just finished tearing down the short motor and everything is pretty much bang on with factory tolerances which is awesome.
The deck needs a machine as it's slightly high in between two of the cylinders.
The head I've got is coming off my the RB25 that was in my 33 until I cooked it. it's a little melted in cylinder #1 as you might have seen in my other thread, it's also not perfectly straight, but I was thinking if I take about 0.8mm off the head it'll remove all the melted crusty shit and increase my compression ratio too. As 25\30 combinations with stock RB30 short motor and stock R33 25 VCT head will yeild about 8.2:1 Compression Ratio, saving the head that much will reduce the Combustion chamber volume by about 7cc which will increase the compression ratio up to around 9:1.
I'm not sure if I want to do that yet though, with the doughy compression ratio and a safe tune I'll be able to use the shitty fuel, down on the peninsula and other Rural areas that I frequent, safely.
I just measured my head and it was 61cc. While I was measuring it I left the water in there for an hour and found all the valves leak a little, some more than others, but they'll all need some love.
I plan to do the internal VCT mod as outlined in this thread. http://www.skylinesaustralia.com/forums/topic/251669-rb2530-rb30det-vvt-internal-oil-control/ Page 5 'The mafia' comments with some pics that breaks down the process really well. Looks easy enough :)
After reading the 25\30 thread in the forced induction section, it all looks too easy... (famous last words)
The only thing on the shopping list is an oil pump, I'm thinking stock RB25 until should do the job? If anyone has one lying around after an upgrade, let me know!
I think I'm almost at the stage where I can send stuff off to get machined! It's looking good so far :)
https://www.sau.com.au/forums/topic/416493-zoid-builds-a-2530/
Pics
RB30 goodness
:D
Proof of concept
Measuring combustion chamber and valve leak testing.
After about 1 hour this is what they all looked like
This piston is the only one I'm worried about, opinions? Spark plug ceramic trolled it.
Extended shopping list:
Oil pump
Water Pump
Full length crank collar
Oil restrictors
New bearings
New head bolts\studs
New head gaskets.
Bottom timing belt gear.
Harmonic balancer
If anyone has this stuff lying around, let me know!
I'm also after a turbo, not decided on what I want to do yet though :/
Edited by zoidbergmerc
This is for the VL isn't it? Not your 33...
.8mm is chopping a fair bit out of a 25 head... I'll be interested in what Matt/insert chosen machinist has to say about it. You'll have to watch your valve clearance too. That head looked pretty fkn cooked though!
I have some slightly used wiseco rb25/30 pistons/pins/locks without rings going cheap if you wan't some :-)
If it's just a slapper, the sparkplug tip damaged piston will be okish, just smooth the divits out a little, also check the bore very carefully.
I have some 25/30 bits and bobs kicking about. I'll have a look, see what I can find.
The conversion is easy. There are a couple of things that arn't covered in the guide, sing out if you need a hand.
J.
When you measured the head did you put clear platic + grease over the combustion chamber for an accurate measurement? 0.8 will not give you 7cc, 86mm diamiter at 0.8 height gives you 4.6cc, so it will probably be 4cc by the time you equate for the sqish zones.
I asked Rodgers to take 4cc out of Steves RB20 head (stock head is 40cc), and he wouldn't do it. He would only change the deck height on the block. He will be able to sort the piston though.
I can't see valve clearance being an issue with the design of the rb30 piston, what is the volume of the piston dish?
Use brake cleaner to test the valve seal before final reassembly, If you used it now it'd be alike a tsunami coming though.
J.
Yeah this first one will go in the VL, assuming it's a raging success I might build another one for the 33 :)
I might take you up on that offer for extra assistance. Let me know what bits you've got, I might require them.
The bores are pretty healthy, they've got some marks where the pistons were sitting stationary for 5 years though, and that comes out rather that eating in, so I'm assuming that can be honed out, the marks came off the piston skirts with a good rub.
I've got to drop some stuff off to Rogers on Wednesday so I'll spin a yarn and see what he reckons.
You're right about the cc part too, f**k knows what was wrong with my maths :P
When I did the head CCs I didn't have any grease or plastic so I just made sure it was perfectly flat and ran a ring of detergent around the lip of the combustion chamber to eliminate the meniscus.
Measuring the Piston dome trolled me a little, it took a while to figure it out, it's got a little dome and a little valve relief. I could measure the relief quite easily but to measure the dish; I made some play dough and pressed the piston into it and measured the dome like it, it wasn't the most accurate way to do it but it's all I could think of :/ By my awesome calculations, the valve relief pretty much cancels out the dome. Both 3.9cc
I'll be sure to clean up the valve seats and try it again later :) It wasn't quite a tsunami, but it wasn't pretty...
are the pistons domed or dished in the middle? it's hard to tell from the photo.
You'd be best just to get Rodgers to reseat the valves, it's not that expensive, and it'll save you 11ty hundred hours
They're domed in the middle, and dished with the valve relief is.
I'm trying to do as much as I can in this engine build, so next time when I hand over my hard earned cash I can fully appreciate the value of the work being done.
Hey Nowley,
Do you have turbo/hot side allready? Do you have a loom ecu yet?
If not, why not put a single cam head back on?
With all the money/time you save, you can put a nice big cam and rocker gear in.... and be able to use the stock loom with a nistune in the VL ecu.
... just a thought
Justin.
There is actually a high flowed 34 turbo here....
Hmmmm.
I don't rate hifliws buy on a 3l it wouldn't be to bad. Depends what you are after. I've got exhaust manifold and turbo lines if you think you mite go that way.
yeah I've still got my stock exhaust manifold and a small collection of turbo lines. So I should be right. I'll keep it in mind though :)
I was also eyeing off that GT3540 for sale in the other thread, will that fit in stock low mount position?
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
