S A U - N S W Tech Night 21St Feb - Detailing
  • Replies 256
Posted Images
Nice, easy to get to! I play soccer across at Wilson Park or something :D
Its across from silverwater correctional facility just fyi for a rough picture where it is
Edited by CLNSKY
Are you and Dad Members then Mick?
I can't tell with this iPhone.
Btw anyone who isn't a Member yet can opt to join up to take advantage of discounts (if they wish to) :)
Well I'm interested if there's a spot left.. or any cancellations! :no:
There's quite a likelihood that someone will drop out. If so, I'll PM you > you reply within 2 days. :)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
