Really? Pm where from was looking at them before however they were either expensive or had a long wait on them.
I have done the same recently too, but i dont know what im doing with it yet.
Nengun. :)
But there is a 2 week lead time on top of delivery time.
I still don't know what I'm doing...
niiice, with all sensors n sheet?
Yup!
nengun looks the cheapest Nick
http://www.nengun.com/greddy/multi-d-a-gauges
That.
Who on here is good with setting up boost on Greddy Profec B Spec II's. I have been trying but ended up confusing the f**k out of myself and turned it off.
Anyone that currently has one running? Also if you could supply me with the settings that would be awesome
Ive got a brand new one for sale Krish but unfortunately I never got around to installing it so can't help bud.
It's a popular unit so there should be plenty of peeps that have used them.
Pretty sure the operating manual is avail online too bud.
Yeah its an awesome unit. I have used it for years and it always works well but in the past they have been tuned when I was getting the car tuned. Now it just has a stock turbo so have to re tune it to bring the boot level down a bit. I found a few tips and hints so will try that on the weekend.
woah def not worth that much for a kit car.
Expert opinion? Once you start ticking the options on those RCR kits, they get pretty f**king expensive. Add on drivetrain, shipping, local engineering..
Guest
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
