So I imagine that the original issue was that the rings were never bedded in correctly?
I suppose this is testament which proves the "get load on the engine ASAP" run in method.
What run in method was originally used?
Glad to hear you have it under control!
I'll be interested to see how mine goes if/when I get down to Collie, venting the sump seems to make all the difference
I think nearly everyone will be - if only because I can now stop sulking about it.
Possibly to probably. Certainly the original engine had far too much blowby which is usually an assembly issue and given the workshop who built it specced it, installed it, fired it up and ran it in - if it wasnt an assembly issue then it is/was still their issue. By the time I got to confirming how it was all done I was so far over talking the said workshop and generally dealing with their &^%$ I never did ask.
For what it is worth having spoken to a number of other engine builders and to Pacific Engine Parts themselves the CRC + drive it on start up (ie dont let it sit at idle) is the way I would be doing all engines in the future.
Also for wha it is worth I rechecked on the oil return diameters in the old block. They are 8mm which is slightly larger than the head. The head got drilled to match the block - which is porbably a mm or so smaller than most people do. Anyway those five returns probably add up to well under half of the total return area.
Edited by djr81
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
