Selling off my collection
1. ARC titaium front pipe for GTR33/34 twi 70mm in 80mm out 650
2. Twin Kakimoto exhaust GTR33/34 950
3. Single Kakimoto titanium exhaust with s/s muffler 650
4. HKS super drager 600
5. S13/14/15 90mm no cat twin resonator exhaust 500
6.GTR34 Getrag 6 speed fully check and rebuilt, no shifter 2900
7 2 of ZX300 5 sp gear boxes check over in very good condition @800
8 RB 25 GTST 5 speed box 1100
9 S15 6 sp box recon 1200
10 GTT34 genuine Vielside front bar in yellow with indicator lights, plenty of downforce 900
11 GTST 400R style front bar unpainted with indicator light 400
12 GTST side pods and rear pod unpainted 400
13GTR34 front bar with grill and badge 700
14 GTR34 middle front lip 250
15 GTR34 Vspec II/NUR OEM carbon bonnett with scoop ( over 10k new) 4000
16. GTR33 OEM alloy bonnett with Nismo lip 800
17 GTR33 Japanese made carbon bonnett with pins, no vent 600
18 S15 Vertex front bar 400
19 S15 Exedy cusion button fully recon clutch 500
20 S15 Sard fuel regulator and 4 ID 1000 injectors 450
21 S15 Cusco coil overs , missing helper springs with 2 of them ( like to buy 2 helper springs ) 400
22. Ohlins GTR33/34 fully adjustable coilovers , excellent for street 1100
23 GTR33 Cusco front upper control arms 350
24 Nismo short shift for 5 sp GTR box 300
25. RB26 fully recon head ( machine shop cost 1070 1700
26. Japanese safety 21 bolt on 6 point cage with plate and hi tensile bolts 800
27 Tilton alloy peddle box no cylinders 400
28 Gmax 2x18x8+38 with Toyo R1R 2x18x9+35 with Toyo R1R 1000
29 2 sets of Ray light weigh tri-spoke 5x100 wheels one set with Toyo RA1 1200
30 Dunlop sports king road and track tyres 265/35/18 one test session only 1200
31 S15 power FC ADM 700
32 S15 power FC JDM 700
33 GTR34 NUR OEM ECU 300
34 BNR34 Power FC 700
35 S15 ADM ECU 150
That is all I can gather, more to come, pic on request, prefer local pick up on large items
pm/call/sms Alex on 0433878905
  • Replies 62
Steve
Sorry,RB26 head sold pending payment.
Will take pic of Cusco coilovers for S15 ( missing helper springs on 2 of them)
pm me details/pics of the s15 coil overs cheers
Pic of Cusco coilovers forS15, still looking for pair of helper springs for the rear. ( missing)
On the rear coilover ,one side says CUSCO IG31 220 619 ARR KYB,, the other side says CUSCO KK19 rest is the same, there are no knobs for damping adjustment, got tops, of course height adjustable, no C spanners
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
