Selling off my collection
1. ARC titaium front pipe for GTR33/34 twi 70mm in 80mm out 650
2. Twin Kakimoto exhaust GTR33/34 950
3. Single Kakimoto titanium exhaust with s/s muffler 650
4. HKS super drager 600
5. S13/14/15 90mm no cat twin resonator exhaust 500
6.GTR34 Getrag 6 speed fully check and rebuilt, no shifter 2900
7 2 of ZX300 5 sp gear boxes check over in very good condition @800
8 RB 25 GTST 5 speed box 1100
9 S15 6 sp box recon 1200
10 GTT34 genuine Vielside front bar in yellow with indicator lights, plenty of downforce 900
11 GTST 400R style front bar unpainted with indicator light 400
12 GTST side pods and rear pod unpainted 400
13GTR34 front bar with grill and badge 700
14 GTR34 middle front lip 250
15 GTR34 Vspec II/NUR OEM carbon bonnett with scoop ( over 10k new) 4000
16. GTR33 OEM alloy bonnett with Nismo lip 800
17 GTR33 Japanese made carbon bonnett with pins, no vent 600
18 S15 Vertex front bar 400
19 S15 Exedy cusion button fully recon clutch 500
20 S15 Sard fuel regulator and 4 ID 1000 injectors 450
21 S15 Cusco coil overs , missing helper springs with 2 of them ( like to buy 2 helper springs ) 400
22. Ohlins GTR33/34 fully adjustable coilovers , excellent for street 1100
23 GTR33 Cusco front upper control arms 350
24 Nismo short shift for 5 sp GTR box 300
25. RB26 fully recon head ( machine shop cost 1070 1700
26. Japanese safety 21 bolt on 6 point cage with plate and hi tensile bolts 800
27 Tilton alloy peddle box no cylinders 400
28 Gmax 2x18x8+38 with Toyo R1R 2x18x9+35 with Toyo R1R 1000
29 2 sets of Ray light weigh tri-spoke 5x100 wheels one set with Toyo RA1 1200
30 Dunlop sports king road and track tyres 265/35/18 one test session only 1200
31 S15 power FC ADM 700
32 S15 power FC JDM 700
33 GTR34 NUR OEM ECU 300
34 BNR34 Power FC 700
35 S15 ADM ECU 150
That is all I can gather, more to come, pic on request, prefer local pick up on large items
pm/call/sms Alex on 0433878905
  • Replies 62
Steve
Sorry,RB26 head sold pending payment.
Will take pic of Cusco coilovers for S15 ( missing helper springs on 2 of them)
pm me details/pics of the s15 coil overs cheers
Pic of Cusco coilovers forS15, still looking for pair of helper springs for the rear. ( missing)
On the rear coilover ,one side says CUSCO IG31 220 619 ARR KYB,, the other side says CUSCO KK19 rest is the same, there are no knobs for damping adjustment, got tops, of course height adjustable, no C spanners
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
