Guys as you know I have an r33 GTR and according to my tuner it's due for a fresh of oxy sensors.
Here's what I need help understanding..
I'm using r32 dumps which have an opening to suit 12mm sensors - I.e NTK OTD2F-1P and or standard.
From my understanding 33 and 32 use different type of sensors - zircona vs Titania . Would it be fine if I was to use Titania oxy sensors on my 33?
Btw I'm using a power fc
Any help appreciated,
Cheers
https://www.sau.com.au/forums/topic/417278-oxygen-sensor-dramas-r32-vs-r33-gtr/
You have two options...
The one mentioned above which I prefer,but takes alot more time to tune the low load/crusing section of the map which results in better fuel consumption if done properly or...
There is "O2 sensor reg." in the ETC. menu of the pfc which allows you to choose between r32 and r33 type O2 sensors.
If I remember correctly, off(+ sign) is r32 type. The info is floating around here....somewhere
Found the info. from Paul and its the other way around.....My bad,but as I said i just turn them off :)
apexi's official answer;
There is a difference in the o2 Sensor for these vehicles. (With or without internal register)
After tuning, please check () "O2 Sensor REGISTER" for BNR32, and NOT for BCNR33.
So off (+sign) is for r33 type sensors
turn off the o2 feedback and leave it off - tune around it
+1
always got better economy with it off and a good tune, and just leaving a dead sensor in there or a bung.
The factory O2 Sensors tend to fail more often in modified examples as well so better off just getting rid of the expense.
  • 1 year later...
Threads like this one are the reason why I keep coming back to SAU.
I have a late model BNCR33 engine in my early edition BNR32.
I installed an AEM wideband and it's constantly reading rich (14+). A couple of weeks ago, I checked the spark plugs and they were very filthy with fuel. I tried my best to clean them but a friend said I should completely replace them. I'm planning on doing that but I want to find out why my GTR is running so rich.
I think I tracked the problem to my O2 sensors via a mechanic that was doing some different work on my car. I have BNR34 VSpec dumps with BCNR33 O2 sensors installed on my BNR32 Skyline. I also have a Mine's ECU that's in need of a tune or change. :-(
Do you guys think that using a stock ECU and/or changing to BNR32 O2 sensors will improve my fuel economy?
Thanks for the clarification, Hadouken. If the spark plugs are filled with fuel, wouldn't that indicate a "rich" car?
Ido,
I don't have the stock ECU any longer. Is it possible to but a used one from the auctions and still have it work on my car?
Ido,
Yes you can buy a used one or a PFC... or a plug in Link or Vipec will go in the case inhabited by your Mines chipped ecu.
I think that's what he meant: "your gauge us shit."
Let me ask you guys something, is it possible to go on a 4-5 hour road trip in the current state my car is in? I have to drop off my vehicle at a friends place that's quite far
the wide band sensors can crap out too not just the gauge. hard call there....if you are worried i'd say stay off boost and you should be ok....but in the end its up to you. I'd re-check your afr's if you can...seems weird you'd be 14's and have fouling plugs...check your breathers and make sure your intake isn't all gummed up with oil vapour residue etc.
it should be pretty obvious when they don't work....the one we were using that was faulty would only read down to 11's before giving no reading.... you should be running around the low 12's to low 11's on boost....strangely your car is quite like my wife's car...bnr32 with bcnr33 motor.
Just to confirm my own thoughts? Doesn't the o2 sensor only work during lean cruise?
I thought the ecu only uses it at lean cruise (closed loop monitoring) where it looks for the rich or lean side of lambda.
that's why it flicks around 14.5-15.5-ish back and forth as it continually looks for and aims for lambda 1.
Then when you load the engine from cruise to accelerate it will give a solid afr and richen the more load increases.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
