March progress pics (taken with the galaxy note). I have lots of work to do, lost some weight but, my commitment hasn't been that great. So it needs to go up alot.
Hopefully I can do better before May.
Edited by rev210
12yrs ago training hard for reference where I am today (muscle strength I have today is mostly legacy from then) . 440kg warm up set on the hack squat machine, real set was 520kg for 3-5reps. I am no where near as strong in my legs today. I squated 250kg for reps back then.
Like to get back to the strength level.
Edited by rev210
Even when I thought I was a hero I wasn't that strong, granted I have a light frame but still. Have you always been naturally strong? How tall are you etc.
No homo, just curious as I watched that 105kg military press video and my eyes almost fell out.
Edited by ActionDan
192cm tall.
Strength training is the key. I have some genetic potential for sure (good at sports etc). However, I did some specific tecniques back then that gave me the basis for what I have left.
The training is hard not because of volume but, because there is very little and huge rest periods. Both when at the gym between movements and also sometimes I wouldn't train for 2 weeks (at all no body splits nothing)
I was a skinny dude growing up. I am not sporting a huge frame.
That's pretty tall for back when you would have been growing up, no offense My point being that heights seem to be increasing on average these days.
And yeah I was skinny as well, 65kg when I left high school then embarked on an 18mth mission an got up to 95kg.
Interesting approach. I got stronger and bigger back then, no doubt, but not to those levels, clearly wasn't doing it right.
I was almost 30 then. I was in 80 something kilo range.
the training program was geared to power and strength.
Years later I was at my biggest around 112 kg from memory and then later 103 but, very lean. That required lots and lots of food all the time and wasn't that enjoyable for me. Being 112 and with a bit more fat, I remember going to Tahiti and having a go with the strongmen on volcanic rock lifts (pick them up and stick them on the shoulder to get the 'good lift'). I had drank a stack of Hinano beers and managed to keep up with them and matched their biggest guy on the largest rock (snick under 400lbs from memory) Not really using the technique that was clearly a good idea , I was very sore the next day ha ha...
I think back on that and can see why strongman events might interest me. then again they stuff your body up too from what I gather ha ha..
The rocks are tricky. When I had the largest one I think they were concerned as I was going to fall over (a well founded fear as my table had many empty beer bottles on it). I will admit that a few blokes were helping to stop me falling over on the biggest rock. They aren't as smooth as they look, they are rough and scratch the crap out of you.
this is what they were doing. In a skirt mind you.....
lift complete.
Edited by rev210
  • 2 months later...
Aproaching D-day for the 40 goal but, it's turning into a longer term thing (fit in the 40th year?). I had some big set backs since I last posted started getting in the way. It's a learning thing as you try to get stronger mentally against the 'excuses'.
My job pressure took all my momentum out till the other day I handed my notice in. It's still just an excuse that I need to learn to remove from looking after my fitness goals. I am slowly getting back on track but, the lack of eating (skipping meals to get work done) has taken a toll. I don't think I have gone too far backwards in physique but, strength is down and so is flexibillity.
I tested my self yesterday with some push ups. A few sets with about 45-60 sec rests and then an all out (managed 70 pushups in a row). The baseline of 70 seems ok. I do these strict. I should try to get 100 out in a row.
* 26 reps
* 26 reps
* 33 reps
* Scapular pushups 20 reps
* 70 reps
Edited by rev210
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
