  • Replies 41
My DR30 has 160,000 on the clock and I'm pretty sure its been wound back because thats incredibly low for a 20 year old car... but it does feel resonably tight still, carpets arent stuffed, pedals are ok, engine feels ok and still goes pretty well (apart from the rings probably needing to be done)
EDIT
Just checked, Mine has 166,000km on it now, but I've been doing 400/500km a week for the last 3 months, and it has a engine flush sticker on the radiator with a printed 200_ with an imprint from a '2' on the _ then imprint of 11 18 and at km it has 152,000... so if it had a flush at 152,000km in November 2002 the 166,000 has a chance of being real? Because it was imported late last year
there was a section writen up in the DRIVE newspaper section about odo tampering and apparently there is a mob in New Zealand that can check digital speedo cars and tell if it is accurate because there is about 5 places in a cars electrical system that stores the odo information apart from the odo
at the end of the article they were saying that they were in the process of coming into the australian market for grey imports.
yeah I got in contact with these guys, they should be up and running here within 3 months. The idea was to get a group buy going for skyliners :rolleyes:
Why does the odo reading such a big fuss for you? I mean, a car with 100k clicks on it really diss you hey? I'd rather look for a straight car with minimal (or no) mechanical fault then be contempt with it.
Another thing you might be able to spot whether the car has been winded back - look around the car for oil change or mechanical repairs related labels. Japs loves them..and look on the rocker cover (or usually on the cam belt cover bit) if the car has changed the timing belt, chances are there should be a sticker and if there's a rectangle mark on it..chances are the timing belt has been replaced before AND it's probably be closer to the 100k clicks on the odo even if the odo says way less than that.
Seriously man i cant believe you expect tp find a 6 year old car with 25,000Kms on it... Low kilometre, never used dealership condition imports dont exist, if you want this kind of a car than you have to accept that theres a good chance somthing will go wrong and you will have to do some work!
Whats wrong with buying a fecked R34, body straight but engine on its way out and rebuilding it? Youd have a brand new engine then wouldnt you!
Either way good luck dude!
Um ... this is to Jam*353 and dairyboy:
IF you read my post carefully, I didnt EXPECT anything, and that includes unrealistic expectations such has a 6 year old car with less than 60,000 kms on it. I even quoted Merli's post on this area.
All I wanted to do was to engage a discussion on what people thought about the fact that potentially a lot of their imports Odometer's had been played with.
Mate, you want to buy a car that has had its clock wound back, had parts changed out of it for dodgy ones, etc etc, fine you do that. You have your standards, I have mine. I cant belive you are having a go at me just because I wanted to get people's opinion on something. Far out I thought that's what a freakin forum was for.
I bought 2 GTS4 r32s in NZ in april 99, they were both 1990 models, 1 had 107000, the other 110,000 kms. They both ran ok and had straight bodies, I've always bought cars on the basis of the body first, it has to be straight. AS long as its straight use the doubtfulness of the kms as leverage when you are buying the car, say you not paying the sticker price and walk out if they dont play ball.
Skylines will do a lot of kms, a 120,000 km example isprob better than an 80000km one as it will have had new cambelt etc. I have a friend with 260,000 on it and its still on original motor, got another auto in the last couple of weeks.
-as per dairy dude.
A telltale sign of odometer tampering is when the silver cambelt sticker on the cambelt cover is missing along with the numbers being out of alignment on the odometer.
The dealers usually clean the cover and spray all that silicon crap on it to make it look like new. If the sticker is missing you can be fairly sure the belt has been changed and the car has done close to 100,000kms. mine still had the stickers, one had no writing on it, the other had 72000 on it.
I have seen cars in yards in NZ with the stickers still on it and the dealer has forgotten to change them - one had more than a 100,000km discrepancy.
I agree you can not expect the norm to be low km cars, it is the exception just as it is here. Maybe gtrs dont clock up the kms as much as the cheaper skylines because they are more collectable but they are cars that get bought by people who like driving- not parking. otherwise they'd buy a pulsar or something.
my 2 cents
Stephen
Ferris Buhler stuff :D
petrol in the UK cost more........so does parking.......petrol.......public transport is cheaper...... and 2nd hand cars have less k's on them then aussie ones do.........not allways, but generally if you were to look at 100 say.
i'd think Japan would have a similar situation...............
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
