I've got a set of 555cc injectors for sale if 32gtr ones fit the 33 rail? Can anyone confirm this?
gtr injectors are topfeed, he would be after sidefeed, unless he converts the rail to topfeed,
Options? Buy my car, strip all the go-fast bits off it and transplant them to yours, then sell everything you don't want from what's left and save a f**kLOAD of cash.
Do it.
Haha, it's called a project for a reason but thanks anyway
So many decisions to think about, Motor is healthy had an easy life and compression test was really good.
Anyone bought/used or know of someone with this setup?
http://www.ebay.com....=item3a74cf4a27
Decent price, just some info would as i don't know anyone with this.
laggy not to mention it's a yum cha turbo.. plus stainless manifold, asking for cracks
http://www.ebay.com.au/itm/RB25DET-GT35R-500HP-Turbo-Kit-Manifold-Wastegate-Turbo-Nissan-Skyline-R33-R34-/251067845159?pt=AU_Car_Parts_Accessories&hash=item3a74cf4a27
I wouldn't use that turbo / wastegate / manifold if I was given it for free. Last thing you want is to scrap a healthy motor because you ate an impeller from your Jackie chan turbo.
300kw on budget =
Std intake & exh manifolds
std cams
Fmic
3" exh
Z32 afm
3076 turbo internal gate with good ebc.
E85 with 1000cc injectors + walbro 400lph pump
Then what ever ecu your tuner preferres.
300kw on budget =
std cams
Fmic
3" exh
Z32 afm
even more super budget:
std cams
Fmic
3" exh
Z32 afm No AFM, find an ECU that uses a MAP sensor
3076 turbo internal gate with good ebc. Hypergear Turbo with Gate Pressure
I dont have a cheap ass budget, Its going to be build by the end of the year, I could be buying a 3076 garret just waiting. As for e85 is it worth it? can't i get the ECU setup to have 98&85?
I want a half decent setup for 300rwkw, If i go the Z32 afm that will allow more air correct? I've got a Greddy front facing plenum already.
Get rid of afm all together
Go flex fuel setup
With 3076
1000cc injectors
Do it once do it right
Then save up for the eventual rebiild or engine replacemet cause the power wont scare you for long and the 3076 can squeeze out a tad more than 300rwkw
Considering both ethanol production plants are in Queensland you should be able to source some e100. :)
Otherwise, look up Caltex or United's websites and see what pumps are close by. I would have done it for you if you had your location. United are selling e85 for 25cL less than unleaded. It works out about the same cost per Km as 98 from my experience.
Couldn't i get the ECU to have like 2 maps ( forgive me not very good with terminology of ECUs ) so i could have 1 for E85 and 1 for 98? I won't be daily driving it, once a week i reckon but wouldn't it be best to have the options?
I can get it from Capalaba apprently, and i live close by so sounds good to me lol!
Once you go e85 you won't go back.
I have been using it for 4 years now, and I just take jerries on long drives. There are plenty of e85 threads on here if you want some more info. Best mod you can do, by just changing servos...
You will need a decent ecu to run flex fuel (any percentage of ethanol) otherwise you will have to drain your tank to swap. Do some research as you are stuck with it once you decide on an ecu, make sure it will do what you need it to.
the one your thinking of is just near the gateway on kessels rd, theres three others which are at springfield lakes, coomera and marsden, cheapest has been $1.06/L but usually around $1.20 which is like 45cents cheaper than pulp..
Also dont get in a habbit of running on the empty line, just incase the pump is out of order, thats happened to me a couple of times lol.
I dont have any fancy ECU, mines just a power FC thats tuned very safely to allow for variations , and so far theres been nothing significant because my knock levels never exceed low 20's on the power fc. :)
Edited by AngryRBGTX
Just get a adaptronic ecu, thats what i have, it can run both fuels, u just need a sensor or a 'sniffer' as they are called and u can fill up with either fuel, best of both worlds if there is no e85 on pump at the servo.
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
