Hi All,
Shopping for slotted rotors for my R34 GTR.
Was hoping someone could point me in the direction of a supplier that still has the DBA 4000 old wiper slot pattern if possible.
Maybe someone still has old stock etc remaining on the shelf?
Just a personal preference, however if necessary will settle for the new style design.
Thanks.
Old design -
New design -
When new models come out, like most things, the old stock is returned to the manufacturer or sold on 'special' to clear and rebates given.
You'll have a hard time finding them in most instances. What business wants to carry old stock when customers want new stuff? :)
The old design was prone to cracking when pushed. It makes no sense to try to get the flawed design now that its been superceeded with a better design.
^^^ this
Adam recalls how these were prone to cracking.
Any slots that go to the edge, and at right angles to the edge, are prone to cracking.
It's the same principle where...
* a glass cutter needs to go right to the edge for glass to crack - if it doesn't it's hard to snap
* a tablet that is scored across the middle to enable a 1/2 dose needs the scoring to go to the edge to facilitate cracking
So you wouldn't want to have your rotor slots anywhere near the edge; or worse still, perpendicular to the edge.
The "NEW OLD" model fixed this problem, the slots stop before the edge by around 5mm, on the front anyway, and I never heard of anyone having problems with the rears.
Skylines are far too front heavy for the rears to get the same level of heat/cracking going on.
Most people will replace the fronts twice before even touching the rears once in most cases.
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
