Hi All,
Sorry if this has been asked a million times before but my M35 Stagea (Auto) is having stalling issues. It seems to pick it's days (ie. it won't stall for 3-4 days, then stall 5-6 times in one day, mostly worse when it's not 100% warmed up). I have replaced the fuel pump and filters, cleaned the throttle body (mostly just dirt, but did appear to have a little oil in it - please not leaky turbo :S?). I am going to attempt to clean the AFM and have a new air filter on it's way. Any other thoughts?
The only other issue that I'm aware of at this stage is the 4WD light coming on from time to time (I'm fairly confident it's just low on ATESSA fluid but just haven't got around to replenishing yet), is there any chance these are related?
Any help would be amazing! Thanks :)
https://www.sau.com.au/forums/topic/418365-m35-stagea-stalling/
Yes I have, why do you ask?
It's the car I supplied the pump and Filter for. I wanted to have a look at your car running.....If you want and your around Hornsby PM me and I'll have a quick look at the car.
I'm pretty sure I'll be able to diagnose it but I need to see it running.
cheers
Craig
cheers
Craig
Hi Craig,
I would love to come down it's just finding the time. Working full time out west, no where near hornsby haha. I'll see what I can do and give you a call! Thanks for popping up.
Update: Today is the first day I had the check engine light come on, I got ECU codes of 0100 (P0100 Mass or Volume Air Flow Circuit Malfunction) and 0235 (P0235 Turbocharger Boost Sensor A Circuit Malfunction). I cleaned the mass airflow sensor and still the same code appeared (and it stalled at the first test). Starting to get pretty concerned about this, any suggestions anyone? Also have a periodic 4WD error light, could this be related (checked ATTESA fluid and it's full).
  • Like 1
What is the idle speed?
There was a factory recall on the Cam angle sensors that can cause random stalling. (basically it will shut the engine down and light up the check engine light) They put a round silver sticker on the drivers front suspension upright, near the manufature plate. Have a search for my thread about this problem.
Is it possible Hills tried to reset the idle?
Best bet is to visit Craig.
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
