  • Replies 53
i think that CS_180 you dont even have a car or maybe youve been driving your mum to long.
hahah gotta love mum jokes.
anyways if you have something to say drive your 180 down to sydney if it can make it and tell me personally.
AHAHAHAHAHAHAHHAHAHA :) - man, i think back at SDU or even here a while ago, there was a thread for 'funniest threads' and this would soooo be in the running.'
i have NO IDEA what's prev gone on with all you mofo's but keep going, cos i'm laughing my head of.
especially...
Mark, if I win I take the rezpeck for some people thats more important
hahahah :) :) :rofl:
am i correct in saying Duncan, you were at Targa Tassie? If that doesn't qualify for "getting your cars out and racing them" i have no f*cking idea what does, full F1 team?? :confused:
This thread has been locked in the meantime while I find out what it's starter would like to do.
Be patient, it will be reopened in one form or another.
EDIT: Thread response recieved from started and as a result I have taken a large pruning implement to this thread.
  • 4 weeks later...
Ok Guys, This thread has been reopend and the Off Topic threads removed or the thread altered to give only advice (no personal touches) where it was given.
I will be monitoring this thread and any Off topic posts will result in a warning.
Thanks for your co-operation.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
