Grass Funkhana, $15 Entry! This Sunday The 3Rd Of Feb.
Ok, there's a Funkhana (a not serious, Fun Motorkhana) being held by the Austin 7/MG club, this Sunday the 3rd of Feb.
It's being held at, Logan's Farm, 192 Bittern-Dromana Road, Merricks North, and the event is run from 10:30am to 4pm. You'll need a CAMS L2NS license or above to enter
What with the new peninsula link open it's a very easy drive down there. The surface is a smooth grass with almost no chance of damaging your car. So come on down and learn that handbrake and slippery powerslides .
Contact Ken Price CompetitionDire[email protected]u If you have any questions
Entires and Supp regs are here,
http://www.mgcc.com....2013-comp02.zip
I've entered, and am 100% attended, so if your keen let me know and we can cruise on down.
Just get down to CAMS one night this week if you can. They can do it on the spot, or failing that give CAMS a call and they can do your license and fax/email sort out a temp. license thingy.
Sunday is gunna be funz!!!
Can't do nights, will have to do it in day (work afternoon/nights).
Hang on, I've just remembered my car is getting new set of coilovers which I don't think it'll be ready for the weekend.
Adrian, can you get a temporary cams licence (or something like that lol) without being a member of SAU Vic?
I'm still waiting on my application to be processed and would love to give one of these a go. cheers Alex
YEEHAWW!!! its a good ol' fashioned paddock bash....that needs a cams License :rofl:
smooth grass will last about 2 minutes before its ripped to shreds yeah maybe I should I bring the work ute...probably got more grunt than an old MG anyway..??
Wow you posted that up quickly haha
For anybody wondering, this an extremely fun (and cheap) event, definitely worth checking out for a day :D
Wish I could make it, but at Heathcote at that day :)
Can you enter if your running an external gate? Would be pretty funny leaving a line of smoldering grass behind you.
inb4 A Current Affair "Are Hooning Import Drivers causing bushfires? The truth that THEY don't want you to know..."
I'd contact SAUVIC membership and get something temporary to show CAMS to show your paid up and proud... fax/email or even something written in ancient hieroglyphs , Then get your butt down to CAMS and get a license ASAP. CAMS can do it on the spot, they have done it for me before. At the very least CAMS can do a Temp license.
Temp license without club membership proof.... your gunna have a bad time.
Really how much damage to grass surface could a MG/Austin do, with their single spinning Diffs???? Wait till the EVO7 gets out there and rips the shit out of it! :whistling::devil:
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
