Hi all,
I have been researching off and on into what turbo choice to run on my R34 NEO. I have emailed a couple of tuners for advice and keep getting different ideas and power figures. To start this is what I currently have engine wise:
- 3" custom turbo back with race cat
- Power FC
- HKS intake
- Cooling Pro FMIC
- Greedy boost controller
- Split fire coils
- Z32 (not fitted)
The car will be kept to mostly street use with the occasional track day. I am after a responsive mid range (responsive) over top end power. I also want to keep the engine looking as stock as possible, since I get enough attention as it is. So my obvious choice was a high flow. I have read into and asked around about the Hypergear turbos but have seen mixed emotions about them. I have asked several tuners about their thoughts regarding their turbos and have been given negative feedback (I don't want to mention the tuners names on this forum). I have been given a quote from a tuner in Perth for one of their high flows at $1250 and looking at 350-370hp at the wheels when pushing them hard. I also have been looking into the GCG GTS-T's at $1955 with a slightly lower power figures. Both turbos are in my budget range but I'm not sure about pushing a turbo to it's limits to get the power out of them. I am hoping to get close to 450-500hp at the fly. Am I best to wait and save for something like a GTX3071R kit from GCG?
My other mods include:
- Pedders coil overs
- Slotted rotors
- Braided lines
- Brake stopper
- redstuff pads
- Half rollcage weld in
Cheers
https://www.sau.com.au/forums/topic/418730-r34-neo-turbo-choice/
You can get to 450hp (fly) with a Hypergear highflow of the R34 turbo. Can also stretch that towards 500 with the bigger rear. Good response. Can't imagine that you'd go any other way given your stated aims and desires. Cheaper than everyone else's options, plus they will sell you any later developed upgrade options at very small prices.
HG or Kando etc.... Been proven so many times on here.... Go through the RB25 thread, so many good results from so many big name tuners... The NEO is a killer engine!!'
Is it simply because the worshops I have spoken with are trying to sway me towards their more expensive high flows?
Because they want to sell you one perhaps. HG build identical turbos for every one, the mixed results can only indicate some have better setup and tune. by following their feedbacks people don't initially getting what they want are getting around the target HP on the end. Also appears Stao is very skeptical about WA tuners.
I've been following the HG thread for few years and got one my self doing 280rwkws with no problems. you can get responsive 250rwkws with their R34 high flowed turbo no worries.
Since you've got a OP6 Turbocharger a standard high flow on stock housings can get you about 350rwhp mark with good response. Reference is at:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__6580
Alternatively you can pay bit more for the billet SS1PU high flow which comes with a larger .86 turbine housing and a stronger actuator. Power wise it makes around the 350rwhp mark with excellent response, wide power band and plenty of torque. reference to look at is:
http://www.skylinesa.../page__st__4460
Tuner is very important, I have recommendations in the east but yet to know any on the west. if you have a Nistune chip, I can forward you with a map for reference once work has been done.
No worries, I'm currenlty running a Power FC tho. Just a quick one, with the SS1 how does it compare to the SS1.5 response wise? I wouldn't mind going a little bigger so there is room for improvement later on. And at the same price, I don't really want to be doing things twice when I get more power hungry. Thanks
Dont mind the mixed emotions re the hypergear turbos. A careful read of this forum will tell you ALL turbos are a mixed bag for results.
The most raved about turbo of all time is the garrett GT3076R (3037 spec) and on this forum and all other OZ based forums there are as many good results as their are bad, a real mixed bag. Plenty of ppl making 300kw, plenty making 240 and anywhere in between.
The trick is in setting up your car right and not giving your tuner a nightmare to work with. A neat tidy and functional setup is best. I myself have gone a hypergear and was very careful with my setup. Like others I reaped the rewards.
The best thing for you to do is to consider A: how fast you want the car to go, B: how much power/response will be required to do that and then C: what turbo will achieve that result. The answer to A is entirely up to you, but the answers to B and C are within the dyno and turbo specific threads on this forum.
Good luck!
No, they are not identical.
The HG bearing case is journal, and this is where the ~$500-$700 price difference comes from.
Where the GCG (for example) are ball bearing case. Garrett Ball bearing cores are around the $1000 mark in that frame size, it makes sense +wheels/balancing +machined housings, makes sense they are then more expensive.
Also note that becoming a SAU-NSW member gets you 10% off GCG turbos :thumbsup:
Thanks mate, I was wondering what the cost difference was for. What are the advantages of the ball bearing core? GCG quote that their high flows are good for 240-250rwkw at 18-20 psi which is a bit below my goal. If only I lived in NSW I would thanks mate, I've only just moved to Perth.
Have a read around the internet mate - You'll see the pro/cons and then make a call for yourself.
Something else to think about - 500hp (over 300rwkw) on a RB25DET doesn't seen to last forever, users slowly but surely running around those figures are seeing their 15yo motors fail.
So unless you plan for a rebuild, peg the power back a bit to 250-260rwkw/18psi and let it live on like many have for years with whatever turbo you select.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
