  • Replies 249
As mentioned by Eric, we'll be discussing this tonight at the Club Exec monthly meeting, but if we want to enter as a club, I think we'll need to do a co-ordinated entry, so we'll need details from interested people ASAP. (I've only had a quick look at the entry form, but that's what I gather is required so far.) Once we figure out if we're going into this as a club, we'll work out the details from there.
Registered as well :) Got 3 others coming as well!
Nick, if you and Eric need any help for anything, let me know mate. And try get a sign up sheet + stickers, I know i'll finally join up again if there was lol
I thought we weren't going to tell anyone, Mat.
:laugh: what happens on SAU stays on SAU!!!
We will make sure we find you somewhere outside the event so we can park together....
hahaah there will definitely be large queues at certain times during the night.. just like last time. I'll be there early early helping out TSI ;)
If they let us, maybe 'double park' if people are late and then reorganise when they get in?
Yeah, what happens if 2,000 people get VIP tickets. Might be quicker to pay on the night :D
I will bring my latest addition to the stable...
LOL good point :P
Hopefully I have my crank seal replaced in the GTR by then - I won't be booking VIP until then, but if it is fixed in time I am in!!
Already rostered off on the day to Wash the car :D
haha dedicated! My car will be coming as is, but hoping the dark will hide the imperfections :P
Lucky I have a flexiable roster - I just work Wed instead of Friday :D
My rear bar is absolutely ####, maybe the tech night will teach me something to fix it!
Black car as well - shows all the dirt :(
Offer your car up as the example car at the tech night. Will come out sparkling.
Hot tip for the day
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
