  • Replies 249
I'm going to try to get a couple of execs to pitch in some ideas about meet up points. I know everyone in here is trying to assist and some good feedback and ideas.
It's just a logistical nightmare considering all the cars and other clubs that will be in attendance facing the exact same dilemma. Remember, the other clubs will be going through this same discussion, hence why I say expect all close in side streets, lots, etc to be a bit chockers.
Also, we want to ensure that this event doesn't become a drama for the local businesses. If they complain then it could cause problems for the organisers.
Any execs input is appreciated, however, from benm (who works in the area) & driving the area under normal working hours to scope the suggestions (as I will be on my way home from work everyday till the event) will probably be more beneficial & practical for meeting point locations.
We all know there will be an excess of other cars (local & from other clubs) in the area on the day, which we all seem prepared for. Practically speaking though, it makes sense to meet around there for members not from Sydney, than somewhere like Wetherill Park or Arndell Park. Huntingwood is easy to get to.
Most local businesses would be used to events of this nature (being right next door to a racetrack & the time of the event), especially around the weekends, as long as we don't get in their way & we behave ourselves in name of the club, we shouldn't cause too much disturbance to the locals.
VIP ticket has been acquired :happy: !
Looks like the S15 - Two Guys from Tokyo Initial D edition will be making a leisurely appearance.
If only there was "Factory Panel Gaps" awards I'd be sure to take one of those out :laugh:
There's a best presented award. Want to swing past my place on the way so I can give your car a quick polish?
You should charge extra for the Sack Wax!
On reading the fine print on the entry ticket the VIP Pass gets you access through the Competitors entrance where normal entry is via the spectators gate and the long access road.
Competitors entrance here we come !!!
Looks like the S15 - Two Guys ball sacks edition will be making a leisurely appearance.
fyp, for accuracy
Just confirmed my place. Is the SAU group still a green light? perhaps I should spend the 10 to sit next to someone of my kind.
Edit: If it is or its full, VIP Club members, propose a meet up point! I'm only 15 mins away from eastern creek.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
