So neither of you have donated? I don't see any stars.
eh? everyone in this thread has a star under the avatar (except merli :()
in your control panel / user prefs have you turned off avatars or something :confused:
There should be no reason why you can't see it.
Can you list from top to bottom what you can see on the left hand side above and below your avatar?
Merli, have you donated? :confused:
All I see normally is the Username, then their comment thingo + [avatar] + and then their details - eg. Name/Location/Car etc. Except when I'm reading a private message sent by me, then I see a star as well.
Judging by what others are saying it appears I'm not alone.
where my star at :rofl:
From Account: 3206 1004 7239 Streamline
To Account: 062-197 10030825 Christian Biggins
Amount: $20.00
Description: 4 SAU-funkymonkey
Date: 04/11/2003 Time: 06:54:14 Sydney time
Receipt Number: N133703530411
yes I know I only donated $20, yes I'm a tightarse... i'll donate more once I get them caps n shit made up.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
