Hi all,
Regrettably I have to sell my car due to moving overseas (to NZ). I have owned this car for a little over 1 year now and since then have hardly had the opportunity to drive it. It was off the road for most of the time while I replaced the engine and added a few extra bits. Sadly now it must go to a new home. The paint/body work could use some t.l.c but could be a lot worse. I would love to restore it to it’s former glory but sadly can’t.
The car was imported from Japan in 2005. I am the 3rd owner since it arrived. The 1st 2 were brothers. Bought the car with 107,000 km’s on the clock and I've put a total of 3,500km. So barely been used in the last 12 months.
I am looking for any interest in buying the car as is. It is currently unregistered but was previously registered in QLD. I recently moved to Sydney and haven’t had it rego’d yet. I did have a mechanic check it over before moving down here and a few bits need fixing (some worn bushings and a gearbox mount). I have most of the bits needed to fix it and they will come with the car.
1989 R32 Nissan Skyline GTR
Roughly 110,500 km’s on the car
Roughly 75,000 km’s on the replacement engine. Came from a ’94 R32 GTR front cut. (The old engine oil pump broke and engine seized).
Twin HKS 2350 turbos
Mines 600cc fuel injectors
Mines Air Flow Meters
Genuine Mines Tuned ECU (can come with Apexi Power FC and Hand controller for $800 more)
Autobarn88 600x300x100 FMIC with hard piping kit inc. HKS front pipe
Twin Blitz BOVs
HKS throttle body gasket (also have exhaust gasket never fitted)
Bosch 040 in-tank fuel pump
Apexi style air pods
Extended Sump
Standard internals
Oil filter relocation kit with HKS oil filter.
Autobarn88 Silicon hose to replace all heater hoses and radiator hoses
Brand new fuel filter
Brand new Water, Power Steering, A/C Belts.
Brand new NPC 5 puck organic clutch and lightened flywheel to suit cost $1200, also replaced clutch release bearing at the same time as well pedal very light but awesome grip.
3” Veilside Evolution II cat back exhaust (very nice noise, not too loud. Can come with spare exhaust that was originally on the car. Straight pipe from cat to back 3.5”)
Modena Racing 17x9J Alloys with near new rubber (Tyre make and model)
Aftermarket fiberglass Side skirts, not sure what brand but they are cracked and could do with being replaced/repaired.
Tein adjustable suspension.
Brand new upgraded slotted and drilled brake discs front and back with new pads.
JIC racing front upper control arms
HKS Turbo timer
GRID HICAS electronic lock out
Greddy Boost controller
Trust boost guage
Black Widow alarm and immobilizer with remote central locking (was fitted when I purchased car)
Alpine head unit with removable face and remote control
Recaro drivers seat (was worn/torn and now patched, see pic)
Momo steering wheel.
The only thing really wrong with this car might be the paint work, it’s a bit ptchy on the spoiler and there are a couple of scratches here and there but to be expected from a 24 year old car…
I think that is about it but I may have missed something.
I also have some other spare parts that can come with the car: brand new adjustable cam gears, brand new Gates racing timing belt, Apexi Power FC with hand controller, 3.5” straight pipe exhaust (very light), “twin turbo” pipe + more…
Car is located in Sydney (2114)
Viewing welcomed/encouraged.
Looking for around $16k as is where is or I will be looking for $17.5k when I have time to get it back on the road.
Contact 0406188865 for viewing/questions.
Many Thanks.
Will get pics up this evening...
https://www.sau.com.au/forums/topic/419395-eoi-1989-r32-gtr-syd/
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
