when will i have to do head bolts and head gasket? at what power or psi can a stock rb25 handle safely ?
Not really a real answer to that one. Its all in the tune. Some people break cars with >300 some people have cars for years with <300.
Mine has been in the 280-300 (dyno dependant) mark for a couple of years now, and gets the living balls thrashed off it on the track. And im not totally gentle on the street when im feeling frisky.
  • 1 month later...
  • Replies 75
Posted Images
My build has slightly changed
This what I'm buying for my car
Gtx3076 .83 with 40mm external gate
Hybrid low mount manifold (keep it looking stockish)
Z32 air flow meter
Walbro 400 just in case I go e85
Bosch 1000cc injectors high Inpednce (unsure if they will fit with standard fuel rail) and do the injectors have to be flow rated for each cylinder ?
Unsure if I need ignition coils and fuel reg ?
The car has done 135xxx ks
Any options please tell
Thanks
You are right to be scared, the factory head bolts are good but they won't hold the head down forever. Personally I would go with the GT3076 unless you plan to change the headgasket and bolts down the track and lean on it some more.
Mine has held 23-24psi for a while now ... GTX will be the wrong choice for your power goals as they seen to act more like a 35r than a 3076... You have so many choices of turbo for your power goals...
So a gtx3076 dose not spool as quick as a gt3076r ? It's response is more like a 35r ? Eg more laggy ? So a better choice will be a gt3076r or a gtx3071 ?
How about Bosch 1000cc injectors
Do they bolt straight in to the standard fuel rail ?
Nope, the GTX3076 was meant to be a quicker spooling turbo etc etc but it has been tried and tested and is not proving to be that way, it makes good power IF you push big boost.
The GTX3071 has had awesome results if you look up Mick_o then you will see what i mean, perfect example of a well built streeter!
You also have too take the time to check out the HG and Kando threads as well as the RB25 dyno results thread too see that Garrett is only one of the option for you.
I love my 3076 and will be staying with that size even with the upgrades.
I dont have a standard fuel rail so i cant answer that BUT i am pretty sure they do with the addition of a spacer, there is a thread on SAU about it somewhere.... I have 2000's now and they were a b**ch to fit!
My GTX3076 is nowhere near as laggy as a 35r, but the I upgraded from GTX3071 was much nicer to drive daily. It just depends what you want from your car and the sacrifices you are willing to make.
The 1000's are longer than the 2000's and should drop in, but nothing is ever easy when it comes to performance mods...
I'm guessing the GTX3076 is good for around 400kw pushed hard on e85, and the GTX3071 around 350kw, or 300 on 98.
Putting the power down is the least of your problems at 300+, there are many parts you will need to replace to reliably handle that sort of power, starting with the clutch.
I can get a brand new gtx3076 or a gtx3071 for under 1300 with out a rear housing.
I've got two garret rear housing to chose from .63 and a .82
My other option is I could just buy a core because I also have a spare front comp cover !
The turbo was a gt3040 or gt3082 but the core shit it self !
what computer are you running? if your still to get one then why not get a Hypergear turbo and adaptronic in a package...
The graph of the last Hypergear turbo looks like they would be awesome all round.
+1 For the ecu and turbo package if not yet got a ecu
my gt3076r is on it way :)
im now looking for external gate ! im also thinking of buying a hybrid performance manifold.
ill be more than happy to make 270 280 rwkw so i was thinking a 38mm waste gate
any advice would be great
thanks
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
