  • Replies 65
I remember fapping over the orginial deus ex back in school, but am yet to play any sequels. Generally sequels frustrate me but sometimes they are better, much like movies bar a select few. Have also heard big things about the mass effects but not motivated to play them having never played any in the series. I guess I am at the stage where if I dedicate time to a game it would want to be worth it! Pretty much havent been obsessed with a game since Skyrim
Good thing about HR is that it isnt a sequel to the first or second games
It is set a couple of decades before the first one so story wise it is unrelated to the first, and being made 10 years later, its a new engine, new artwork etc
Oh also Chivalry: Medieval warfare is good fun for the lulz.
This, am enjoying chivalry, still needs a bit of balancing though
Can you fags add me on steam so I dont play chivalry on my own...
jackinthebox222
lol so getting this game, hit boxes look pretty dodge but the gore makes up for it.
Anyone know much about the new CS that's out/coming out?
Wouldn't mind knowing about the new CS as well.
Had a game on source after many years of not playing and loved it!
Hitboxes in chivalry are pretty hard to get used to.
Archers also suck!
Still a great game for a few hours of fun
The new CS is pretty much HD old school. In terms of a game it will not be brilliant. However its CS so who gives a sht.
Daniel add me you fag. Anfanee. Same name on EVERYYYYYTHING. LoL, Steam, XBL (though i never use my sexbox)
Terraria, Minecraft, ArmA 2 (Day Z and Wasteland), Baldur's Gate, Knights of the Old Republic or Chivalry.
All fairly cheap and excellent games available on Steam (Minecraft isn't, but its still excellent).
Skyrim and Borderlands 2 are games I have sunk a boatload of time into. Not a lot else otherwise although I am just starting up Dust 514 (I know, PS3 only. Whatever).
If you wind recent games boring/samey why not pick up a SNES with a disc drive (Game Doctor SF3). Can't go wrong with the SNES classics :)
Funny you should mention that, I was actually trying to find my old emulator/roms the other day :P Seem to have been lost with the new build though...
I read/heard Aliens CM is a major disapointment so I'll probably just torrent it, in the meantime I loaded up MAME again to play some old 90s arcade games to relieve the memories I never had since my grandparents won't let me have any money.
Best place/way to buy BF3?
After watching the yt vid on the first page I had to go watch Aliens :P
And to contribute to the thread I highly recommend anyone who hasn't played Bioshock check it out. Dead Island was a big surprise for me too for a hack and slash shooter
Hmmm BF3
Try get a premium edition straight off the bat because that aces the hassle of all the map packs etc
Check the price through the origin platform
If not then maybe a few of those pc cd keys online sites. They are really cheap
g2play.net for BF3 Premium. It's where i get pretty much anything that isn't on Steam.
So $59 for the Premium and $42 for the extra DLC - and there is HEAAAAAPS of play time.
Wish i had time for gaming atm lol, been 2-3 months since ive even fired up a game.
^^^^ +1
Also the upcoming South Park and the Stick of Truth looks pretty good - if you like the show you will like this....although ETA is sometime this year some say june some say december :(
Edited by milanr34
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
