Well, today is an exciting day for me. I have been after this car for the better part of two years.
After tracking down the lady who’d been driving it, i found out it belonged to her uncle who owned it since new and he’d lent it to her ten years ago! He wasn’t really interested in selling it but after calling up to check every couple of months he finally relented. I had wanted this one to be my tenth R31, but i bought the silo 5 days before as a fixer upper. The simmons will be going on the gts until i can source another pair
It is quite rough on the outside as you can see and the interior needs some work but thats exactly why i’d wanted it. It seems to have all the original bits except for two of the rims – developed the cracks – but im sure any GTS aficionados will help pointing out whats needed smiley.gif
Standard tape deck!!!
Standard speakers?
  • Like 1
well the real miracle about finding one of these is that pete has personally killed more nissan actually made. On the bright side he would have left lots of bits at wreckers
Thanks guys. Im really suprised at how well it drives, handles better than any of my other street 31's
Did a bit of a clean, needs a lot more work but it feels nicer now. The polish worked, it'll need a cut though but im not sure how much paint is left. There’s bare metal on the bonnet
I don’t know if i mentioned it before but the car got broken into a couple of weeks before i bought it. so i had to replace the loom behind the ignition, now i can start it without having to jump the starter haha.
I’ve also ordered a new ignition barrel with extra door lock barrels
Did an engine oil flush as it was blaaaacck and new tank of premium with injector cleaner in it. Must have been some sh1t in it, stalled on me about 20min later and had to floor it to start again with a big puff of smoke. Running much better/smoother now.
Also, I tried to adjust the front bar gap. I think the reo is bent so for the interim i pushed the right side up and pulled the left down so theres about a 10mm evenish gap now. No pic atm
Haha, yep. Got a set of Simmons V4's to go on, just need to get a lip straightened on one.
The ones you see on the silo in the first picture.
  • 1 month later...
New number plates finally got here and i put the fog lights back in at the same time.
Also, shiny new O2 sensor. The old one had a rattle..
Cold idle is new and improved.
  • 8 months later...
Funny you posted now :)
I only just put rego onit and drove it for the first time since june.
But other that that, I haven't really done much to it. Been on the back burner while I've been playing with grumbles :)
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
