@ Mark - here was my previous GT3071 setup revved to 8,000rpm so 4,000rpm would be around 112klms
Did the S15 have a 5 speed box in it?
If the gearing etc is the same that makes GTScoTT's GTX3071R capable of 20psi < 4000rpm - which is really quite impressive :)
Just picked up the car. Haven't had a chance to go for a proper drive yet, but here's the dyno plot:
Boost is both lower and later than I was expecting. I got the impression talking to Josh that they didn't quite solve the boost issue they were having. He mentioned potentially using a different rated actuator spring to improve things (currently 10psi).
Very happy with the quality of the install they've done though. They really took the effort to keep the stock / black theme, and using quality fittings for things like BOV return. Can post up pics if anyone is interested.
Hmm it's strange that it's coming on that late, looking at the curve it doesn't look to be a boost control thing to me. You are running Nistune? Is VCT being used?
That boost curve doesn't look like it is necessarily using the full potential of the turbo but as you mentioned, good chance the actuator is making it impossible to go any further. It's decent power for the boost through, I reckon - and while in the range of what seemed doable there could be a bit more in it with a stiffer actuator.
Let us know how it drives when you get more of a chance! Be interested in how quickly and easily it comes on, the curve makes it look no better than my old GT3076R which doesn't really make sense, I am assuming there is more than meets he eye going on there.
Also for sh!ts and giggles, here's comparison with previous stock turbo (just with exhaust, pod and tune).
When I get a chance will take some photos of install (looks very neat), and hopefully can feedback on driving impressions.
That comparison looks a heap better when comparing apples for apples. So is your Nistune setup running VCT? If that's not with VCT and there is more boost available then the result starts seeming a lot more understandable. Driving (ie, response) should give a fair bit more of an impression of how well it works :)
Thanks for keeping us updated through it all!
I have the Z32 ECU with Nistune so should still have VCT.
Aiming to get a decent drive in on the weekend, but power does feel great when it comes on. But impossible for me to gauge how it is compared to other setups except stock.
OK, interesting.
When you drove it did it feel conspiciously laggier than the stock turbo? A typical "full boost at 3750rpm" combo would feel very noticeable. Maybe we should just let you get the weekend and have a proper go? :D
Perth dyno's always read lower :whistling:
Yep just throw more boost into it once the control issue is sorted.....as it one thing the GTX's seem to thrive on.
Please post up pics.
Edited by juggernaut1
I thought the z32 ecu needs an additional window switch to control the vct.
Mat only very recently added vct control to the z32 ecu's. I would look into whet you actually have it or not.
A quick way would be disconnect vct plug and go for a drive. If it's the same you need to get it working.
Contact matt at nistune about the update.
  • Like 1
Yep. I got z32 and r32 confused!
Still worth checking as I mentioned.
Sounds easy enough to check. I assume it won't hurt anything if unplugged?
Lith, it definitely feels laggier than stock turbo. Need to get out on the weekend when less traffic around so I can try and get a better feel of when boost builds. I will say though that it feels like it ramps up real quick, whereas on dyno plot looks like more of a gentle increase.
Josh did mention that PZP's dyno tends to read low, but I'm not going to put any stock in that unless I can confirm somewhere else.
Can I also get some advice from you guys? I was told that to make use of higher boost, I really needed to look into freeing up flow more (cams, cam gears, and possibly freer exhaust). I was told the turbo actually has quite a bit more to give seeing as GTX series like higher boost, but couldn't get there without these changes. Does that sound right?
Definitely won't damage anything driving with the vct plug unplugged.
I wouldn't think cams are the best use of money at this stage.
Cam gears perhaps, but the dyno time to dial them in might not be worth it.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
