What was previously thought to be a Coil Pack issue now looks like an Air Flow Meter problem.
My Power FC is showing an AFM1 reading of as low as 0.4 while AFM2 is steady at around 0.75. This causes the car to shake, idle rough and lose power while driving.
Sometimes this happens constantly. Other times the Power FC will show both AFM's hovering at 0.75 and the car purrs like a kitten and drives like normal.
Does anyone know whether AFM1 needs to be replaced or is this an issue with the connector/earthing?
I haven't tried cleaning the connector with a spray (I was planning on buying some spray tomorrow).
https://www.sau.com.au/forums/topic/420225-r34-gtr-air-flow-meter-issuehelp/
"This causes the car to shake, idle rough and lose power while driving."
is the lose power while driving at any speeds, or while still in first? i know its a diff car but my BMW had a similar issue and it was resolved by replacing the MAF
Thanks guys!
The loss of power is constant. as soon as AFM1 voltage drops down, the car starts shuttering like it's choking. Every gear and no particular RPM. Had to roll home slowly.
I unplugged AFM1 and it started shaking etc. Plugged it back in and it started idling perfect. This is why I'm thinking maybe its the wiring and not the actual AFM.
As mentioned by basti sounds like it could be the solder inside one of the units meant to be a common thing that can happen ! Are they standard AFM ? Swap them out with someone see if that fixes it if so might be time for an upgrade! Nismos maybe ?
Or just leave them plugged in and run a map ecu. Standard sir
lol he's on his P's in a car that is FAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAR from stock.... AFM's are the least of his worries :P
Chris just swap AFM1 with AFM2
If AFM2 starts playing up you know it's the AFM. If it's still AFM1 then it's electrical.
Realistically though they usually don't drop to 0.4 - they will drop to 0.0-0.03 which will make them flash error/failure intermittently on the PFC... That's just what I found over the years anyway.
Ditch the AFMs, hide the plugs, and get a PFC D'jetro :D
And go through a roadside EPA station and fail instantly because they can't find the plug or do find the plugs, pull them off, car still idles ok - instant fail and easiest way for them to check for full aftermarket setups. Once they get you that way you just get written up for a full inspection on the spot and then they get the camera out which is the worst thing that can happen :thumbsup:
I'm off my P's now :)
Good idea Ash. I'll swap them around and see what happens.
AFM2 is a pain in the ass to get to lol.
If I need to replace the AFM, I doubt I'll be able to get one in time for Tony's wedding!
Because GTR.
I remember Ash popping a cooler pipe at DECA in someone elses GTR... Full toolkit, 2 guys who know their way around.... 30+ Minutes later...
UPDATE: I swapped the AFM's around and it's still AFM1 which has the voltage issue. I guess this rules out an issue with the AFM.
Anyone experienced this before? Could it be the wires leading into the connector?
Because GTR.
That was a pain in the ass, inner guards & supports FT, we cut corner and didn't put anything back in though L lol
AFM's are a bit more fiddly, not too hard though - certainly need less tools :D
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
