Are you saying that above the number plate under the plastic horizontal piece there is no lever ?
I just did what you have done (pushed latch in) and can pull on the latch with screwdriver as suggested and pull lever.
So you can't open your boot if your remote fails ? Battery dead etc ?
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
