  • Replies 70
Not that it makes much difference anyway, but have you removed any weight out of the car Chris? And what exhaust set-up did/do you use on the strip? I'm just thinking out aloud, as I guess there's a few little things that when added together can make a noticeable improvement without needing any extra horsepower.
At the end of the day (and regardless of the above) the time/mph you ran is a bloody legendary effort mate! :cheers:
I riced it up with a pure carbon bonnet + bootlid, but left everything else in there. Exhaust is same as what I run on the street, no cat, and only a Nismo cannon muffler at the rear. Tis a bit loud, but I need all the help I can get.
Oh yeah and I'm weighing in at about 80kgs (gotta lay off the donuts).
I'm a tad over 80kg myself... a little more suited to a 1/4 driver than some perhaps? :)
Chris,
The carbon boot and bonnet would help a little bit. But not that much. As would the nice loud Nismo zorst. I've just switched over to the same exhaust set-up as you mate. I gained quite a bit of extra mumbo from the swap. I gained quite a bit of noise too!
Ok I changed over the rear coilovers to HKS Drag shocks, while I was under there I took a couple of pics of the suspension setup. I forgot it has a full Nismo link kit (both F+ R), but I doubt that is as effective as adjustable heim jointed upper arms.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
