Up for sale is my pride and joy..
1999 R34 GTR V-Spec in Kr4 Silver
60,000kms
selling to fund an investment property.
car currently has 358awkw tuned at Morpowa on 98 octane.
modifications include:
Trust T517z turbos (10cm)
Tomei 260/260 Camshafts and cam gears
Power enterprise 700cc injectors
Jasma full twin system exhaust
Nismo AFM's
Nissan N1 spec water pump
post-80026-0-70512000-1361775827_thumb.jpg post-80026-0-97261500-1361775879_thumb.jpg post-80026-0-42402600-1361775895_thumb.jpg
post-80026-0-88486000-1361775922_thumb.jpg post-80026-0-79179300-1361775962_thumb.jpg post-80026-0-05820500-1361785976_thumb.jpg
post-80026-0-80493600-1361787422_thumb.jpg post-80026-0-79298100-1361787461_thumb.jpg post-80026-0-19263500-1361787500_thumb.jpg
Trust oil cooler kit
Blitz 600hp front mount intercooler
twin thermo fans with triple core radiator
standard air box with K&N filter
Splitfire coilpacks
ported turbo manifolds
bosch fuel pump
trust oil catch can
TEIN coilovers
Cusco camber arms
Alcon 365 6 pot front brakes
Alcon 335 4 pot rear brakes
project Mu pads & titanium wheel nuts
Volk TE37 18X10+12 matte black wheels
toyo 265/35 T1r tyres
Nismo clear indicators
factory uv cut privacy glass and dark tint on windows
NISMO 320kph dash reading 27,000kms also have original dash reading 32,000kms
kenwood cd player and speakers
blitz dual sbc
apexi hand held power fc
blitz turbo timer
Ogura twin plate clutch
and much more...
over $36,000 in receipts for work done recently
just spent $700 on full service at Manta Automotive
serviced every 5000kms have all history on car with receipts.
car is meticulously cared for and rarely used
non smoker - washed weekly
premium plates 'XX 034K'
have lots of standard parts which go with the car
please call me on 0411 768 931 for more details
Thanks Sam
PRICE $54,999
Edited by APE
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/
No idea sorry mate I did not remove it, is it important?
Car has no accident damage or evidence of repair and has matching numbers etc. I have a fast screenshot but its on my work computer will post later this week.
Sam
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6772102
I'll give this a free bump purely because it's everything I'd be looking for in a GT-R.
Unfortunately, the timing is not quite right for me at this point, and believe me, I ran the numbers more than once!
Good luck with the sale.
Edited by ActionDan
https://www.sau.com.au/forums/topic/420597-r34-gtr-vspec/#findComment-6802549
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
