i just bought my first skyline to but not my first car. I live in NSW and am on my Green Ps but atm the car is unregister so there is no temptation to drive it and lose my licence. i dont think you will get exampt. how long do you have to go till you get your open licence?
  • Like 1
i know people may think that and im not going to try change it i will accept it and leave it as that, yes i may drive silly at times, but the risk of losing my exemption or licence that i need both for work for is to much so i do the right thing pretty much all the time.
im on my reds and go to first year of greens in September, so a long way yet :/
its 125kw/t
all the rules im talking about is in queensland.
you won't get the exemption because they won't accept a dyno read out as the power figure
anyone could go and get their car detuned to a low dyno read out to send in with their exemption application and then head back down to the tuners the next day and get it tune back to 200rwkw.... have you considered this ?
as above, i have my doubts about you getting an exemption. let us know how it goes though.
many have tried to thwart the system, none have. I spent quite a lot of time back in my early P plate period trying to find a loophole in the system.
"no vehicles over 6 cylinders" - "but sir! rotaries don't have cylinders"
you just have to deal
Edited by alex182
its 125kw/t
You won't be granted an exemption, so I have no idea why you keep thinking you will.
Is there any other difference with the 94?
One of my grandfathers coworkers is a skyline nut. And says that a good mod for me to do would be upgrade the front hubs to r33 gtr hubs (hubs rotors and everything) he said the reason for this is to go from 4 pot calipers to 6 pot
Would this be worth the effort?
No silly driving just my grandparents are all anal about saftey in cars like breaks and tyers
They said they wanted me having bigger breaks and slotted and drilled on the car I said I will just get slotted rotors and new pads to fit what's on there.
Skyline nut that thinks the factory Brembo's are 6-pot, good stuff :laugh:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
