I have no problem with speed cameras. If u dont speed u dont get fined or lose points. Speed cameras, mobile or fixed aren't a problem. Drink drivers and actual hoons are a problem as are fatigued drivers. Middle aged men who can't time manage properly and leave for work 20 mins late and HAVE to tailgate in their sporty as f**k Mazda 6 are a problem also. Just sayin'
I have to admit my occasional guilt to this here, though in my 34.
Lol I'm late far to regularly, but that doesn't mean traffic can do 50 in a 70 zone. I agree with the speed cameras and red light cameras, if only they displayed the speed properly at Moore Park road :angry: . Safety cameras only work where people know how to drive and have common sense, which on Sydney tend to be not that common (e.g. slamming on the brakes because light went yellow, even though you could have safely made it doing the speed limit, but then, who does the speed limit these days?).
Here's a standard: If it takes you more than thirty seconds to reach 60 km/h, get off the roads.
Not enough people blast their horns at below-par drivers. Car in front doing 60 in a 70 zone with nothing to prevent them doing the speed limit safely besides themselves? Depress horn button on steering wheel.
I do it occasionally on the freeway, but it seems that they think YOU are in the wrong, despite the highly-visible "Keep Left..." signs. Usually it's a quick flash of the high-beams as I approach them from behind - some people get it, and some people (it seems) don't know what their mirrors are for, or why the hell I'm flashing.
It's even more annoying when there are a CHAIN of cars all swapping into another lane to overtake a right lane hog, and it still doesn't sink into that person's head.
:domokun:
Observed Cultural Differences Years Ago
(I don't know if anything has changed)
* Hong Kong - Flash the lights > people move
* Bangkok - Toot the horn > people move
* Sydney - Flash the lights > people stay put
* Sydney - Toot the horn > you cop middle finger
* Sydney - Blast the horn > people brake hard
* Sydney - Train Horn > people move
Got tooted yesterday going over a rail crossing at about 50km in a 60 zone. Not to mention the rail crossings are terrible and it's like a roller coaster ride. I resisted my urge to do the both.
I think the major factor is mentality and daily stresses that people go through. Putting up with terrible traffic 24/7. I've found the further away from Sydney you go, the friendlier the traffic is.
Sydney has nothing on Victoria.
We have to make sure it doesn't end up like our Mexican neighbours.
Driving down the freeway- these are my notes/differernces
-Fixed speed cameras have nil signage warning of their location
-Police actively hide, including behind bridges, and within bushes in the median strip making it impossible to see them.
- Unmarked random cars parked on the side of the highway contain speed cameras.
- Cameras on the back of bridges
And lets not forget the polices shoot and ask questions later policy.
Train horns are for chumps. Real mean use ship fog horns:
On a more serious note, NSW isn't anywhere near as bad as Vic. Just stick to the speed limits and we won't have to pay voluntary taxes. Cruise control comes in very handy for this purpose.
Edited by ras1983
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
