Thank you to all at SAU for making my first time at a grip event an enjoyable day. I was pretty happy with the GTR. I think its the first time in 3 years it had a decent thrashing. I just need to get my times lower.
Hope all is well with the Fliggymobile
  • Like 1
Great day guys, big thanks to everyone who played a part in organising it! I threw a power steering belt on my first lap of the day...so off to Repco for a replacement. Thanks to the lads who gave me a hand to get it changed over quickly and get the s14 back on track asap! Ended up pulling a PB with a passenger in the car...first time I've done that! Did a solo run after and ended up getting another PB of 1:16.01!! Very happy with how the new tyres/alignment went, was also good to meet a few new faces.
Awsome day taking the new 32 for it's first grip day. Massive thanks for the SAU SA Exec team for organising the day, great work and the layout worked really well. Hope next time I can have decent tyres instead of 205's all round.
Massive thanks to Munro for the burn in the 33, best car I've ever been in.
Had a blast on the burn out pad at the end hence why I went back out. Ended up splitting a heater pipe at the end so spose that's good compared to what else could have happened and car will be fixed Saturday.
Fliggy
i know i just brought a new turbo :w00t:
Didnt take long, oil cooler arrived this morning! Thanks Australia post.
A HKS 2540r is on its way, maddddddddddddddddddd. anyone know all good places to get a custom intake made
or a club sponsor
https://www.facebook.com/pages/AM-Performance/135203453221377?ref=ts&fref=ts
yeah i rang him today and he will make me one. So getting the built
need to get manifold modified which is sorted injectors fuel pump and another tune.
Has anyone ran/run this turbo? any good
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
