If you want to check your CAS (this is for CAS with mitsubishi logo):
• Pull the fuel pump fuse out
• Start engine over until it dies
• Unplug the CAS
• Have your handy modified spark plug lead and timing gun ready
• Remove the three bolts and carefully slide the CAS out. Try spinning the shaft on the back. It should spin smoothly & freely, if it's hard to spin and/or has a grimey/scratchy feel to it (metal shavings), it's likely cactus.
Optional: You can try cleaning it by removing the three screws on the back, and the two screws on the metal plate that goes around the plug. Once the three base screws are out and the metal plate is removed from around the plug, give the shaft a couple of gentle taps with the rubber handle of a screwdriver and the case will come apart. You do not want to bend the disc inside so be careful. Don't bother removing the two screws on the black plastic thing inside too, there's three little delicate pins inside it that seem like they don't want to let go. If the disc inside is ok and not bent, hose the inside of the CAS out with mass airflow sensor cleaner and reassemble.
• Plug the CAS back in again, turn your key to ignition on and slowly spin the shaft by hand. You should hear your injectors clicking. If not, check the plug, if still no go, CAS is buggered.
• Check the seal/gasket between the CAS and the engine, make sure it's still good, put a dob of grease in the end of the CAS shaft, align the half-moon thingy to match the half moon position on your cam, carefully slide it back in and do up the three bolts to finger-tight. Put fuel pump fuse back in again. Consult FSM on re-setting timing to 15 degrees BTDC, then tighten the the three bolts up (don't over-do it).
If any of this advice is wrong I happily stand to be corrected... I did mine recently using the above method and it still works perfectly ;)
Cheers
Ok so have taken it to a workshop, i have been told my ignition module isnt grounded and when i ground it if it still is f**ke cld mean its broken or the cas is gone, i also need a new catylac converter and to get my pipe welded(f**ker snapped)
no, just pop it on a dyno so you can measure rpm vs. a/f and also push the car without breaking the law
most operators will charge around $100 to pop your car on and test it..
$800+ is for a tune including dyno time
  • 3 weeks later...
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
