Hi All,
Engine with Paul currently however he's been a little hard to get a hold of of recent times.
Has anyone heard from him lately I know a few guys were in regular contact in Newcastle.
Cheers
C.
I saw him 2 weeks ago. He has engine's coming out his ear holes at the moment...just be patient.
Edited by wedge_r34gtr
  • 3 weeks later...
  • 3 months later...
Eh.... Still trying to get my engine back!
Finally Spoke to Paul a month ago and he said the engine will be done within a week of the 5th June and the 12th has come and gone and still unable to reach him...
And the stories just keep going, and going, and going.
From now on - anyone mentioning this person/buisness, who keeps doing wrong by SAU users - Will have their posts edited/hidden.
Even if you try it via PM, it won't end well.
We will no longer let people be screwed over, regardless of the 'fan club' that persists on here in recommending someone that just continually wrongs people.
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
