Bench form needs a little work. You need to get the scapular retracted more and the sholders in a better position of rotation. Whats with the towel?
Curls , too fast. squeeze as hard as you can at the top of the rep. Lower with a 2-3 count. Keep your body from moving around.
Pin the shoulder blades back together more?
Towel is there as the bench is shitfully uncomfortable with heavier weight, it also reminds me to stop my head tilting and straining my neck.
Curls are too fast due to weight, normally 44kg, other points noted though and I think I heave too much so I might drop the weight, concentrate on staying still, squeezing etc. I will habve to drop the weight to do that which is fine with me.
You need to be able to press like a girl at least.
See how her back over arches in the later reps and the shoulders move out of line with the hips, that's what happens to me, but at only 45kg. Implying shitful core/back strength I assume?
Edited by ActionDan
You need to concentrate on doing it right without a towel. Leave heavy weights till you get it right.
Yes she has nill issues with core and back, you do however. At 68kg she is pressing alot more than she weighs and she can also bench 180kg.
Based on your form with light weight ,your pressing with 45kg would look very ugly as a guess and it's probably hurting you. Her form is spot on for the lifts. She has stabilisation even with the really big weights. Remember that very slight distortion is more due to the weight being much heavier than she is and balance.
With the row, is that enough "bend" or is the idea to go parralell? I know there are different variations but I'm trying to consider my lack of back strength here too and not risk injury.
I'm not out to be a power lifter so "safer" movements are fine if they'll help me get stronger and some shape/size.
As in SLDL "Feels" safer to me, but at only 50kg that may just be an illusion.
Edited by ActionDan
Dislocating my ankle and breaking my leg was an eye opener Nick. I was covering 100ks a month running, as well as exercising 3 times a week and felt like I was in OK shape/had OK strength, now I've spent the last 6mths languishing going backwards etc and furthermore so many other areas are suffering while I learn to walk evenly again etc - as per the myo comments about how it affects my pelvis/back. It's retarded.
And now because I'm working on areas that I've neglected for so long, it's like starting again, so I'm just trying to be smarter about it and avoid further injuries/delays.
But given I, like a few others, started out at 60 odd kg when I fist started lifting, I have no doubt that I can make some progress over time.
everyone starts somewhere... even really strong guys get injured and have to start from the beginning again... your form is fine but your using rubbish equipment which is only going to make the journey longer and more frustrating than it needs to be... look at it as an investment in your health... and it's cheaper than a gym membership in the long run
when you start to get stronger many of the little niggles just disappear... the body is amazing and adapts very quickly but you have to make it adapt... don't over think it... it's good to train smart but you have to train smart and hard... you will have more setbacks along the way, it happens to everyone
Cheers dude, I've had enough injuries along the way to know it happens.
I've been much stronger along the way too to know how fast the body can grown and adapt.
Definitely will get a cage, but my jew nature (when it comes to extra curricular expenses) will see me hunt around for one for a bit first.
yeah of course, you don't need anything fancy... if it has rust on it it's even more badass, that's a fact!
if your afraid of getting hurt you won't get anywhere... you had a really bad injury but eventually you just have to say fck it and trust your body... it will hate you for a while... everything aches and you hobble around like an old man... if it were easy everybody would do it
You've got to get this thinking out of your head. Going through the motions is pointless IMO. If you achieve a goal lifted weight, what's the sense of just forever doing that? Don't you want to better yourself?gives you something to look forward too.
Also, your reasoning for gloves, you'll get better feel and grip without them and guess what? any callouses you may or may not get would be lucky to make contact with the other hand. I have callouses, work in an abrasive industry and my hands are 'soft' to touch so to speak.
Edited by jangles
I have goals, just not power lifting goals like some of the people on here.
And yes at some point I will switch from gain to maintain, you can't gain forever.
I should add I also used gloves back in the day to help support my wrists, these gloves just wrap around but don't have the solid supports up the back of the hands like the old ones did which is fine as my wrists are stronger.
So a bit of an old habit.
Dan, I work as a hand model and look at these mits
I ditched gloves completely (used to use them just for pressing movements) 2 months ago and my calluses are no worse. They're actually lesser/better, because once you start lifting heavy, gloves give you calluses too...in the wrong spots where the material bunches up. They also give you a clitoris and a visit from aunt flow every month.
Try two weeks without gloves; I guarantee you'll stay that way.
I'll try it, easy enough when the weight is light , but nobody is really selling the virtues of not using them.
Though I have noticed that bunching on occasions, more so with old gloves.
I've just finished a quick sess of Cubans and various stretches/rotations for the back, inner glutes, elbow etc.
Will do some more light weights tomorrow and grab the cam and try some of the suggestions.
I also tried the creatine last night, mixed ok with protein shake and didn't effect the taste badly.
Keep it up with the shoulder girdle and lumbar strength building. Deads and squats are great, you can leave bro-press alone totally till you are strong. I will even suggest you can leave it for 6-9 months. Do strict press instead when you are ready, there are other chest building movements.
Wear gloves if you want, who cares. Even better get some foam bar grips. They increase the diameter of the bar making your grip work harder. Being made of high impact foam they will be better on the caluses to boot.
No bench press? But I love bench. I won't be stopping that unless there's some excellent reason not to do it.
Do strict press? I thought a strict press was a standing military press, heels together?
That was something I'd always been told by people who were pro gloves, it added diamterer and made your grip work harder.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
