Without sounding like I'm sassing you, do you follow any religion or something?
Some of your comments are very Zen/Buddha type stuff.
Become one with the bar etc.
No paying you out, just curious as your mentality is quite different to what I normally see in/around gyms and gym threads and seems to be a big part of your arsenal.
I'd be lying if I said there wasn't already a noticeable decrease in nerve discomfort in that leg.
Normally when I stand It twinges every time, it's backed off a bit 0_0
if there is an issue with your pelvis and feet, I can understand how it could be causing pain after squatting or deadlifting. Weight is not being shiffted or moved with the right body mechanics and the pressure is being forced into the wrong spots causing pain.
thats my uneducated theory.
give it a better time, if it doesnt end up working move onto the next thing i spose
Well if nothing else I'm finding new and interesting ways to fail, going backwards at the moment.
Warmed up, did a couple of 50kg reps then moved to 116kg.
Got 7 reps again and went for 8 but didn't have it.
Reset the bar to 100kg, total break 2.5mins did 8 reps, had a 2min break then got another 6 before failing 7.
2min break and found 2 more kg so squeezed that on the bar and did 2 reps of 118kg and failed the 3rd :/
Moved on to chins. Barely made 8 reps at 25kg, dropped to 22.5 and made another 7 dropped to 20kg and only got 6.
Similar story for dips, started at 30kg, failed the 8th rep, dropped to 27.5, failed on the 6th, had another go and got 4 then took a very brief break and managed 2 more. Breaks unless stated are 2mins.
After that did a few body weight only lunges then a plank and a side plank on both sides then another normal plank after some more lunges.
I was shaking doing only 30sec planks, I was doing 2mins at one stage, weak core is weak.
So fail city all round, getting weaker it seems. One session a week is not enough.
Sorry for typos, on the phone.
So Dan,
I'll share my thoughts with you about what happened but, if you could answer these..
first, did you do things the way you 'wanted' ?
second , did you get the result you 'wanted' ?
If you did things the way you wanted , then how committed were you on a scale of 1 to 10 (think of this in terms of passion or enthusiasm).
If you didn't get the result you wanted , what is your response?
I did things the way I wanted in terms of setting myself up to have a go at 8+ continuous reps as right now that's the mark of whether I've improved and I'm just not seeing any gain there.
Did I get the results I wanted, no. I genuinely expected to see at least 8 have a go at 9 or squeeze out 9 and rack it.
Committed as per normal, didn't waste any strength on too many warm up reps, made sure I was really comfy and in good position to maximise my chances. I went for that 8th rep being 95% sure I wouldn't make it based on how much 7 took out of me, but I thought I'm gonna go for it because if I don't try then I definitely won't make it, but if I try it could happen and I really pushed at the "sticking" point to make it go up, but when it starts coming back down you've gotta concede. I've even gone as far as snatching extra breaths which I don't normally do because I don't try for long enough to need that extra breath.
In terms of my response, I'm disappointed, as I thought I'd put in a bit to do those 30 reps previously and was keen to see a gain in the initial continuous reps.
I will note, at the moment when I wake up, I'm not really feeling refreshed. I went for a walk this morning to help me wake up which I had stopped doing because of my leg, Chiro said pelvis will love movement so get walking.
I've been a bit "emo" as Kate calls it, in terms of being a bit meh about gym because of my leg and not being able to do squats and deads.
Commitment is still there, say 6-7, enthusiasm is probably a 4-5.
Light workout last night just to get myself back on the 3 days a week cycle.
Even still, had some bench issues. Went 8 reps at 110 then failed on the 6th rep attempt for the second set (2min break)
Got 2 sets of 20kg chins out and 2 sets of 25kg dips out.
Also did some body weight lunges and some more front and side planking.
I've had no relief since seeing the chiro. I'm still stretching daily and have been walking most days, 3k or more as I've been told to keep the pelvis moving.
Also still doing the nerve glide stretch, nothing seems to help at the moment. Chiro again today, if she's got nothing for me I will have a think about whether oto get an MRI and examine those lower discs (I'm not private health so they set me back a few backs) or go to a podiatrist and get my gait analyzed properly.
See what the Chiro says today. She was the one that suggested the MRI so if there's no improvement or she doesn't feel she can get any, I might just do that.
Back, she said I was very tight again and I said I'd not noticed any improvement. She said if there's to be any improvement it might start after this treatment given how long I've had issues. I go back in a week and if there's been no improvement she will book me for an MRI, so if nothing else she's got a game plan which I like.
She also said core and light leg work are fine, just avoid too much weight or twisting while bending where possible.
At the moment I'm just walking, planking and doing some bodyweight lunges, she said those are all fine.
Rev: You never commented on why yopu thought I didn't make an improvement, fair enough I only had a 2 week go at it, but it seemed like you had something to add earlier and didn't.
That aside, another lighter workout last night getting back to 3x weekly.
Bench 110 for 8 reps then 6 reps, which was only 5 reps on Monday and failed 6.
20kg chins x 2 sets of 8. 25kg dips x2 sets of 8.
2 sets of 10 per leg body weight lunges, 2 sets of 20 body weight calf raises, a 1min front plank, 30 secs each side, then another 30 sec front plank and some body weight squatting motions to see how things feel, I note the bum wants to tuck just above parallel.
I'd also be inclined to say that I am experiencing a little less leg and back discomfort, normally by the end of the day I'll get some real sharp grabs and twinges but they were more minor last night. Whether that's chrio or just movement from walking/squat motions/lunges/stretching I'm not sure.
Sorry about not getting back to you Dan, been quite busy
Consider what is in that goal. you wanted to get a single set of 8 or more reps and not say, continue to train your intensity? When you asked me for some input wasn't it to train more intensely?
The no so secret , secret is what you have been doing so far isn't necessarily about increasing this lift. The things I had you do are about perseverence testing and pushing you into dissapointment. Easy enough to examine your benchpress and program but, if you are giving less than 50%? (based on your numbers below)
You are little low on it
If you are 95% betting against yourself in the mind, will that help or hinder your efforts? Question why you entertain that thought, is it useful?
Thats a reaction. A response is more about what you are going to do about the situation. Also, is it interesting that revealed in that statement is a belief that you maybe have earnt a result from a past effort?
This is something to keep in mind as a potential obsticle but, what actions will you take to address it ,if you consider it one?
Your commitment is set as high as your passion or enthusiasm, so at 4-5 it's less than 50%.
Just to recap. What I have been getting you to do isnt about getting you bench press numbers for one set. What you observed is that when someone provides a 'push' (makes up for the low commitment) you gave a greater effort than left to your own devices.
Think about what is addressable in this. What could you do about it?
Edited by rev210
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
