Nismo Plenum Group Buy #2
Following Sinista32’s successful Nismo plenum GB last year, I’ve decided I would start another for those that missed out.
Time frame: Group buy run’s from now until the 14th April. This end date is subject to change
Price: TBC closer to the closing date due to fluctuations in the exchange rate – estimated to be ~$1650 delivered. A quick Google will tell you this is a very good price.
Supplier: TBC shortly
No of people: 5 is the magic number
Details of the Plenum:
~ Nismo plenum as discussed on SAU. If you have a comment or technical question, put it in that thread please.
- Group buy #1 – info from the first GB plus results
- Nismo information – from this link. (It's the sales speak)
FEATURES:
To find the most suitable shape for tuning engines (400ps to 600ps), the diameter and the length of the intake pipe, and the cross section shape of the intake collector was redesigned. The distribution of air to each tube was improved to provide more equal airflow volume, improving torque in the mid-speed range. Improved air intake volume between the pipes of the front and rear sides reduces the difference in air intake temperature on both sides of the turbine, optimizing the air-fuel ratio and ignition timing and providing increased output and fuel consumption. Simple bolt-on installation means that no additional work is required (however, the throttle linkage and throttle sensor must be adjusted).
SPECIFICATIONS:
- Collector volume: 4.1 liter (genuine = 3.4 liter)
- Intake pipe length: 73.8mm (genuine = 48.5mm)
- Intake pipe diameter: tapered from ø 43 to ø 45 (genuine = ø 45)
- Material, production method: cast aluminum
PRODUCT NOTES:
- Intake temperature difference at the entrance of turbo chargers is improved averaging 18% in 2,400 to 7,600 rpm range.
- At 4,800 to 7,600 rpm, power output is increased by an average of 1.8%, while fuel economy is improved averaging 0.4%.
- This product cannot be installed with the engine mounted.
- Installation of this product will change the characteristics of the engine, necessitating adjustment of the engine control unit. Failure to do so very likely will result in damage to the engine.
- The engine improvement figures shown above are based on internal company testing. The actual level of improvement will depend on the engine specifications, conditions of air-fuel mixture and ignition timing, weather and the precision of measurement.
- This product cannot be used with single, large-diameter throttle chambers.
So who's keen?
Cheers,
Joel
Edited by wedge_r34gtr
https://www.sau.com.au/forums/topic/421901-nismo-rb26-plenum-group-buy-2/
I might be keen, need to find out if this plenum fits in a vl
I assume it should...the stock rb26 fit's ok i beleive.
Never heard of someone putting a nismo plenum in a VL...nice and unqiue :-)
Hey man, will let you know tomorrow if i can jump in on this group buy..
This is an awesome price guys, wont find it any cheaper anywhere else an if you's are serious about your motor you'd have one of these hanging of the side of it!
Congrats guys. I don't think you'll regret it one bit.
...and it's cheaper than our GB.
yep, can't wait to get it. Final price ended up less then $1550 delivered.
So how many people did we end up getting for the GB?
3 of us
Ibz, yourself and me :-)
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
