1992 Black R32 gts-t.
DRIVELINE:
-Series 2 RB25DET motor and gearbox
-Rebalanced KKR430 turbo
-3" Turbo back exhaust (from cat back is Bee Racing(Bee*R) from Japan)
-Microtech LT-16S ECU w/ MAP sensor
-Splitfire coils
-OSGiken Camgear
-Gates Racing timing belt/tensioners/idler pulley
-Sard fpr
- Walbro 255l/hr fuel pump
-Blitz pod filter
-JustJap 600x300 FMIC
-Exedy Sport tuff clutch (the pink pressure plate ones)
-Gibson motorsport custom 3" single piece tailshaft.
-Tuned by DAT performace (the guy who does the dyno at Powercruise)
-Makes 239kW at only 12psi NO LAG! Have dyno sheets.
SUSPENSION/BRAKES:
-HSD coilovers
-Bee*R pineapple bushes (subframe collars)
-KKR Castor rods
-HICAS lock-bar
-DBA Slotted rotors
-QFM700 pads all-round (outperform redstuff)
-Can provide front strut brace
WHEELS AND TYRES:
-18x10 +18 Work Emotion XD9s
-235/40R18 Federal 595s all round with 90% tread
-Guards rolled and pumped to fit the rims
INTERIOR:
-Red BRIDE Cuga Carbon-fibre Drivers seat
-R33 GT-R Passenger seat
-Deep dish suede wheel with yellow centre marker
-Microtech control unit
-Pioneer head unit with bluetooth handsfree
-Pioneer speakers all round
$9500
Car will be sold with RWC, can register at buyers cost after deposit put down if convenient for buyer.
Contact Jono: 0421 308 872
post-46140-0-64362100-1363682653_thumb.jpgpost-46140-0-61819200-1363682666_thumb.jpgpost-46140-0-72524300-1363682788_thumb.jpgpost-46140-0-44757900-1363682804_thumb.jpg
https://www.sau.com.au/forums/topic/421954-qld-1992-r32-gtst-with-rb25det/
I bought the car near stock in 2007 from its first aussie owner 21000km ago, engine and gearbox came from a front cut series 2 R33 with 80000km on the clock and was put in the car just under 5000km ago
I built this car to have real world performance and be drivable and well mannered on the street, things look very stealth under the bonnet and in almost 6 years of ownership the car has never been defected. with some injectors 18-20psi and a small edit to the tune, this car would see 270rwkw+ with no issues.
car will be sold with RWC, can register once deposit taken if preferred (at buyers cost).
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
