Yes.
Apparently ended up in internal disciplinary action for the driver, as it was not his first time.
He cut me off, drastically, so that I had to take evasive action. After I beeped, he then flipped me off and continued to do so up until I pulled over and attempted to gain entry to the bus. He mellowed out after that
Didn't get touched.
Did you get hit?
My old housemate got rear ended, with the driver just driving off.
Ended up going through his insurance, but driver disputed it, claiming my housemate pulled into his lane, reducing his stopping distance
I didn't get hit. Stopped pretty close though. Thank gawd for ebc pads! The backs feel like they have flat spots and I'm also getting a lot of vibration from both rear wheels. Might give the insurer the heads up.
Edit: could be in for rotors and rubber if this resulted in some damage. Am also picking up some noise from the wheel bearings. It's too wet to go and check right now but will ASAP.
similar thing happen to me... had to brake hard a swerve.
beeped, got the finger.
took photo on the plates and note of location.
reported it via email.
got a call the next day. complained more and informed them I'll go to the media.
Bitch got fired.
suck shit kunt!
Edited by TTT
lol... You braked hard to avoid an impact (as brakes are designed for) and now something is wrong and you think they should fix it?
lol... You got no chance mate.
sounds like your car was not road worthy if shit is broken from braking hard.
lol. It was 60 down to 0 very quickly,. All I'm saying is something isn't right. They've fixed wheels and tyres before when it;s been their fault. Shall hear back next week and go from there.
If you hit a pothole and damaged a rim, I could understand that council may be liable (stretch but still maybe).
If you are driving along doing 60 and a grandma in a hybrid camry pulls out of her parking spot without looking and you jump on the brakes and do a little ABS skiddie and don't have an accident, but later you feel that the rear brakes are a bit weird, is it her fault?
I can't see how someone you "almost" had an accident with could be liable for something on your car failing when used as intended.
Just means that the now faulty part was not road worthy.
If you give first gear a push and hit the limiter, then the next day you find an oil leak, are you calling up Nissan?
i had a bus pull out of a bus stop and nearly take me out one day. i know you are supposed to give way to them etc, but he didn't put the indicator on until i had just passed the back corner of the bus and then just pulled out straight away.
talking to a mate who used to be a bus driver, or work in the management side of things (can't remember which), he said that drivers are supposed to wait something like 4 seconds after they put the indicator on before they even attempt to pull out. on the other hand though, he also said that with the new LED indicators on a lot of buses these days, they can take up to a few seconds to start to flash after the driver puts the indicator on. so that just screws everything up.
I'm glad to hear no one got hurt.
Happens on the Goldie as well. Every time I see a bus at a bus stop I try immediately to merge into the other (right) lane if there is one as IMO they don't give a sh!t about you.
Yes, I understand they have a schedule to run and considering roadworks, school zones, etc... they are always under pressure to meet that schedule hence, why they are pressed for to make up time but at what costs?
HOWEVER.....just because we need to give way to them doesn't mean that they have to be arrogant and abuse it and more importantly tag innocent motorists because of that.
I'm certain its been brought up many times before with translink, Qld transport and other authorities, but bottom line is that justice does not prevail. In addition to that the public transport is already bad as it is
What they fail to realise is that if there is a severe prang resulting from such a situation NO ONE is better off as the bus will be reported in an accident, the passengers may be injured, the bus gets nowhere, passengers get nowhere, the car will be totaled and the driver will be mangled, and bus driver will be let off with slap on the wrist.
Its really about time theses bus drivers start thinking a bit more about safety of the passengers and other motorist instead of just a f@#king timetable which already late anyways.
There I feel better and I hope you do too.
Edited by Ants
To the people that said t they got the driver fired or disciplinary action taken against them. Do you actually have any proof of this happening other than a letter saying action has been taken?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
